Hello - Before using the self-cleaning cycle of the appliance, remove the broiler pan and any utensils stored in the appliance. Also remove any excess spillovers in the oven cavity. Allow the oven to cool before cleaning. During the self-cleaning cycle, the outside of the wall oven can become very hot to the touch.
Typically to set the controls for a self-clean the first step is to confirm that the clock shows the correct time of the day. Press CLEAN. "---" appears in the display. Press the UP ARROW or DOWN ARROW once. "3:00" appears in the display for a 3 hour cycle. To change to a 2 hour cycle press DOWN ARROW"2:00" appears in the display. As soon as the controls are set, the motor drive lock will begin to close automatically and the "LOCK" indicator light will flash. DO NOT open the oven door while the light is flashing (it takes about 15 seconds for the over door to lock). "CLn" will appear in the display during the Self-Clean cycle and the "LOCK" light will glow until the Self-Cleaning cycle is complete or cancelled and the oven temperature has cooled.
When the Self-Clean cycle has completed, the time of the day or "End" will appear in the display window and the "Clean" and "LOCK" light will continue to glow. Once the over has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. If "End" is the display and the Clean indicator light remains ON, press CLEAR/OFF. The time of the day will appear in the display.
If it becomes necessary to stop or interrupt a Self-Cleaning cycle, press CLEAR/OFF. Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. Restart the Self-Clean cycle once all conditions have been corrected.
Same as everyone else. The oven has only been in use 3 months tried self clean - no oven. Kitchenaid/whirlpool very sorry but never heard of that fault before, I suggested that was not true and could I speak to someone with technical expertise but no, help line useless. I am getting this fixed under warranty from the supplier but the upshot seems to be don't use the self clean cycle.
have the same problem....never as been solved after 3 times (part change). i do not have the chance of having the warranty anymore, this cost me a lot. i would suggest that if they repair yours, try autoclean it writ away, many times.... this is a consception problem but they do not seem to want to solve it!! they always say that your the only case... probably that a lot of people like me does not use autoclean often and do it after the warranty expires! please put pressure on them for us, maybe after they pay alot for replacing parts...they are gona solve this issue!
thanks
