Question about Whirlpool Duet GHW9150P Front Load Washer
Washer won't start cycle after door is closed
Our washer model #GWH9150P won''t start the wash cycle after shutting the door and pushing the start button. The timer numbers flash and you have to push on the door to get it to lock and hold the door ******* to 30 sec. after it starts or the door unlocks and the timer numbers flash. It never shows a trouble code. It also will stop in the middle of a wash cycle at times and the timer number flashes, (again no code) if you push the start button it will start and finish the wash cycle.
Try taking the top of the machine off and checking all of the electrical connections, including the one to the door lock. I have to do this about once a month with my machine and it seems to work.
Posted on Jan 21, 2009
SOURCE:
Washer stops between wash and rinse, and stays full of water. ld code
see this steps and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Jul 21, 2013 | Kenmore Washing Machines
Skipping wash cycle
follow this steps and fix it. God bless you
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
Jul 13, 2013 | Admiral 3.4 cu. ft. Top Load Washer in...
Affinity stops in the middle of a cycle a just shuts off no signal or anything?
use the following steps. God bless you
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
May 23, 2013 | Frigidaire ATF6000ES Front Load Washer
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
see this causes and fix it. God bless you
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
My compact front load washer won't work on most cycles
this is probably the push button panel or the timer
Aug 23, 2009 | Washing Machines
Which dishwashere auto resume wash cycle when door is closed?
All the tall tub dishwashers made by Whirlpool (inc. Kenmore and Kithcenaid) must have the start button pressed after adding a dish. If the start button control light is blinking, you must press start. On those models with buttons on the top of the door you must, in addition, close the door within aprox 5 seconds after pushing start. Hope this helps. Ken
May 01, 2009 | KitchenAid Dishwashers
Washer runs when timer dial turned though ON button not pushed
Problem solved by ourselves! It was NOT in the circuit board (brain) of the machine. It was NOT in the door locking assembly as others would lead us to believe. It WAS the on/off switch on the control panel--part number 22002560 - a $22.00 problem fix.
Jan 05, 2009 | Maytag Neptune MAH5500B Front Load Washer
Front Loading Duet Washer will not start
You have to set your programme FIRST, then put the "on" switch. Try.
Mar 26, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
714 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
