HOW TO UPGRADE FROM MAC OS 9.2 TO OS X 10?
SOURCE: Problems with Apple 15" PowerBook G4 Aluminum 1.25GHz LCD Display Mac Notebook?
The coonection on the(LCD AND LAPTOP IS BAD The wirng )You have to have it taken apart and fixed. I can do it if you live in California or ship it to me. But that is what the problem is.
SOURCE: Mac Powerbook Software Issues
Hi-
chances are you are having a Corrupt OS, you can actually try to trash and reinstall the softwares that is corrupted or update OS to either 10.4 or 10.5... Hope this helps.
SOURCE: load new apple mac software powerbook g4 15'
Hi;
Instructions for the Mac OS X Password Recovery.
Although there’s no real way to recover a lost root password, you
can change the root password even if you do not know the current one.
You must have physical access to the machine in order to accomplish
this task.
1. Click Restart at the login window
2. While the computer is restarting, hold down “Command-S” until you
see text scrolling through the window. This boots the computer into
single user mode.
3. At the Localhost% prompt type:
/sbin/fsck -y
/sbin/mount -uw /
/sbin/SystemStarter
You will then see various services starting up.
4. When the Localhost% prompt reappears, type:
passwd [username]
It will then ask you to type the new root password twice, so do so.
(Though I’ve not tried it, it appears you can type niutil -list .
/users to get a list if users if you do not know the username….if
someone wants to verify this, I would be most appreciative).
5. After entering the new password, type:
reboot
6. At the login window, enter the username with the new password.
Once you are logged in, you can use the Multiple Users application
(/Applications/Utilities) to change your user’s password, or create a
new user account.
Note: this may not work for newer versions of OS X; I think they did
something about it in a security update. I hope this helps you with Macintosh password recovery.
Note: give some times between tasks, Follow to the letter.
SOURCE: Mac Powerbook using a Dell 810 all in one Printer
No, because that model printer is just rubbish. Throw the thing out and purchase a laser Brother HL-2170 and it will work just splendid with the Apple PowerBook G4.
