SOURCE: NAKAMICHI CASSETTE DECK 1 NOT PLAYING?
it has probably thrown the capstan belt and will require a new belt fitted. the transport relies on capstan rotation to engage play. a separate reel motor operates ff/rew and takeup funtions
SOURCE: Nakamichi BX-125 Cassette DEck
Unit probably needs belts. Over time, belts may become slack or decompose into tar-like compound. In this case, the deck will need to be cleaned and belts replaced. Take to pro/tech
SOURCE: Nakamichi BX-125 Cassette Deck
Check leaf switches and also, press play -- after a few minutes, feel motor(s) for heat build up. If it gets hot, either motor is bad of something is preventing it from rotating
Would be possible for you to tell me were the motor speed adjustment is located
There is typically a small hole in the capstan motor rear cover. This is adjusted with an insulated driver as the case is ground. This must be adjusted with a reference tape as all other methods are not accurate. The Service manual for the unit you have should be obtained and the info will be in the manual as well.
