Open up the dialer and enter - *#06# to check your IMEI number, if you see "IMEI Null or 000000 ", you need to reconfigure the settings to fix the no signal or not registered on network problem on your Android phone.
In the dialer, type- *#197328640# or *#*#197328640#*#*
You will be prompted into the Command mode, provided On the screen, Select on Common, normally option 6
Now Select (FTM) Option 1. FTM (Field Test Mode) is for debugging and testing, if the option is on, you will have to turn this OFF.
As soon as you turn this off, your NULL or altered IMEI number will be restored
(Important) Without leaving the Command screen, press the Menu key, the button that's found left of the Home button.
Select Key input and enter option 2 which will turn your FTM OFF
Wait for a minute. Remove your battery and SIM card for two minutes, place your battery in your phone back but not the SIM card. Turn on the device then.
When the phone is booted, enter the command mode again dial - *#197328640#
Select the Debug Screen, normally option 1
After that, choice phone control, option eight
Click on nas control, option 3
Afterwards, click "RRC (HSDPA), option 5
To Fix not registered on network or Null IMEI #, click RRC revision, option 2.
Choose the released of your phone, here we will choose option 5 (HSDPA only)
The final step to fix Null IMEI # is to turn off your phone and insert your Sim card or else reboot your phone and then insert the SIM card to dial *#06# to see if the IMEI number is restored.
this means you have to send it in to be repaired.
var fctb_tool=null;
function FCTB_Init_b97d054e4c5845d895f635ff3513dce9(t)
fctb_tool=t;
start(fctb_tool);
FCTB_Init_b97d054e4c5845d895f635ff3513dce9(document['FCTB_Init_ddf891a0ff694dfca31906f9e212664c']); delete document['FCTB_Init_ddf891a0ff694dfca31906f9e212664c']
var fctb_tool=null;
function FCTB_Init_c13f1c7e8e2e4e048862e81515c9eb4d(t)
fctb_tool=t;
start(fctb_tool);
FCTB_Init_c13f1c7e8e2e4e048862e81515c9eb4d(document['FCTB_Init_773767694b964746976c86b2d2f97d85']); delete document['FCTB_Init_773767694b964746976c86b2d2f97d85']
1) make sure you are not accidentally touching it so it comes out 2) send it in to get repaired
var fctb_tool=null;
function FCTB_Init_07fad209927241eab20e13d8a38e50bc(t)
fctb_tool=t;
start(fctb_tool);
FCTB_Init_07fad209927241eab20e13d8a38e50bc(document['FCTB_Init_da3c80f351cf488d8c9c6587d4d57ca3']); delete document['FCTB_Init_da3c80f351cf488d8c9c6587d4d57ca3']
var fctb_tool=null;
function FCTB_Init_b32fce540edb4734b1b43037587d5497(t)
fctb_tool=t;
start(fctb_tool);
FCTB_Init_b32fce540edb4734b1b43037587d5497(document['FCTB_Init_3a2967d76b224b55896665859092db56']); delete document['FCTB_Init_3a2967d76b224b55896665859092db56']
try contacting Netflix and or Wii
var fctb_tool=null;
function FCTB_Init_35e413cd0fb34601a94fc5c7be18b8a3(t)
fctb_tool=t;
start(fctb_tool);
FCTB_Init_35e413cd0fb34601a94fc5c7be18b8a3(document['FCTB_Init_19d672db25fe4986b3beb63e803fcbc2']); delete document['FCTB_Init_19d672db25fe4986b3beb63e803fcbc2']
var fctb_tool=null;
function FCTB_Init_4321118e4cce427a84431d02d79eb049(t)
fctb_tool=t;
start(fctb_tool);
FCTB_Init_4321118e4cce427a84431d02d79eb049(document['FCTB_Init_03166db902704a489f96739865b20855']); delete document['FCTB_Init_03166db902704a489f96739865b20855']
you can get a specialist to come and fix/reapply the sensor to the boat and possibly fix it if it is broken
var fctb_tool=null;
function FCTB_Init_4fdf0f4e4d1b403489dd188ff9311fa0(t)
fctb_tool=t;
start(fctb_tool);
FCTB_Init_4fdf0f4e4d1b403489dd188ff9311fa0(document['FCTB_Init_3475a15565eb478ea69972d3c6d88377']); delete document['FCTB_Init_3475a15565eb478ea69972d3c6d88377']
var fctb_tool=null;
function FCTB_Init_a70c5362962d40be976e65b2158646e3(t)
fctb_tool=t;
start(fctb_tool);
FCTB_Init_a70c5362962d40be976e65b2158646e3(document['FCTB_Init_379c2b6472d1424f847e6d43703fa3ad']); delete document['FCTB_Init_379c2b6472d1424f847e6d43703fa3ad']
there are instructions in the instructions manual
var fctb_tool=null;
function FCTB_Init_4bcac70471f442a18162ecb02ba42e76(t)
fctb_tool=t;
start(fctb_tool);
FCTB_Init_4bcac70471f442a18162ecb02ba42e76(document['FCTB_Init_82f35e7ae1b84cf4a4fed8bd2190e47d']); delete document['FCTB_Init_82f35e7ae1b84cf4a4fed8bd2190e47d']
var fctb_tool=null;
function FCTB_Init_a31a1d30df264be5aa0867fe7d4f05ae(t)
fctb_tool=t;
start(fctb_tool);
FCTB_Init_a31a1d30df264be5aa0867fe7d4f05ae(document['FCTB_Init_1de4087967984d4eae9dd6f2f612fc1b']); delete document['FCTB_Init_1de4087967984d4eae9dd6f2f612fc1b']
you may have to remove it and then re-download it.
var fctb_tool=null;
function FCTB_Init_08694a4076884f5c8f74584a43ce6dba(t)
fctb_tool=t;
start(fctb_tool);
FCTB_Init_08694a4076884f5c8f74584a43ce6dba(document['FCTB_Init_ca7c5f366be5437aa818906b1b18ad28']); delete document['FCTB_Init_ca7c5f366be5437aa818906b1b18ad28']
var fctb_tool=null;
function FCTB_Init_fcda81ab4c9d42c098587fa7382f9546(t)
fctb_tool=t;
start(fctb_tool);
FCTB_Init_fcda81ab4c9d42c098587fa7382f9546(document['FCTB_Init_98a9ed8b254b4ca58a1645368e87825e']); delete document['FCTB_Init_98a9ed8b254b4ca58a1645368e87825e']
