Lexmark T642 Laser Printer Logo
Posted on Jan 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lexmark T642 - print is very light
We have a Lexmark T642 printer and have replaced the cartridge because it was printing to light. After replacing the cartridge with a brand new one, it is still printing very light. What can we do?
Anonymous
Level 3:
  • Master 685 Answers
  • Posted on Jan 19, 2009
Anonymous
Master
Level 3:
Answers
685
Questions
Helped
229693
Points
1828
Take the cartridges out and clean the spot they go into then clean them off also
Lexmark T642 print gray though new cartridge
The main cause of light print is a bad set of charge and transfer rollers. These rollers are used to put a charge on the paper and transfer the toner to the charged paper. When the rollers get worn out they can not put the proper electrical charge on the paper so the toner does not stick to it as it should. One roller sits under the toner cartridge and on is on top on the cartridge. If you pull out the toner and look inside the printer you will see the transfer roller and if you start to close the lid with the toner out you will see the charge roller come into view. Here are pictures of each one. Transfer roller first.
These rollers come in the preventative maintenance roller kit. This kit is available at the following link. The kit also comes with the pickup rollers.
http://www.ccl-la.com/catalog/product_info.php?products_id=301
My lexmark T642 printer is printer lines at the far end of my invoices. Is this just a simple cartridge replacement?
It can be the cartridge or the dual charge roller. This roller is located above the cartridge. Take out the cartridge and lower the front cover 1/2. then you can see the dual charge roller. Partnumber 40X0127
How do I clean the heads on a Lexmark T642 as it is starting to leave large ink drops on the paper
A T642 has no "heads"as in an inkjet. "Drops" on the paper are mostly caused by a leaking cartridge. So try replacing the cartridge.
T642 Laser Printer: How do I change toner to my Lexmark T642. I can't ...
Switch off the printer and let the printer cool down. Then on the front of the printer open the release latchand lower the multipurpose feeder then open the top cover by releasing the latch. You will be able then to pull out the print catridge. Hope this helps.
3helpful
Realign the print on my Lexmark T642 printer
You can adjust the print registration settings in the Config Mode of the printer. I believe you hold down both the down arrorw and right arrow button when you power on the printer
Lexmark T642: Will not print text files in Linux
Sounds like there is something corrupt with the driver or the wrong driver is associated with the printer. Delete the printer from the computer, but leave attached. Download the newest driver directly from Lexmark and execute the download. The computer should then automatically re-install the printer.
please visit the link below to download the correct driver for your printer directly from Lexmark.
http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:0:0:0
use the product selector to enter your model number and operating system.
T630 cannot print color
just a wild guess. it may not be capable of printing in color.
check if you indeed have color cartridges installed.
it says B/W - Black and White.
http://www.dooyoo.co.uk/laser-printer/lexmark-t630/
escription: Model ID 0010G0110 / Lexmark T630 - Printer - B/W - laser - Legal, A4, A4 Long - 1200 dpi x 1200 dpi - up to 35.1 ppm - capacity: 350 sheets - parallel, USB
2answers
Printing Issue - Lexmark T642
Chip on toner is bad, try puting in old one to reset and switch it with new one, sometimes turning off and on several times helps.
2answers
You need to download the Postscript drivers from Lexmark site.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
