I bought a Samsung blu-ray player today (Model #BD-E5400). When I connected it to my Element tv (Model #ELCP0371) it shows the Samsung logo and then the tv goes to a blue screen and says Not Support. Can anyone tell me what this means? I called Samsung twice and got different answers both times.
SOURCE: My HDMI connection does not work with Blu Ray DVD
After reading your post a couple of times, it just seems your are in a little of a pickle here. The only thing I can suggest, since your tv will work with fios and not the your BD player(I assuming your using the same port on the tv with the same hdmi cable), is all about firmware. Maybe your tv is not compatible with the the BD player. Try updating the firmware on the tv.
SOURCE: My Samsung Blu-Ray player won't
I hope our talented expert would have given you helpful and correct info
in chat session from related service manual, feel free to ask further
help if required.
Thanks.
SOURCE: I have just about given
Please exchange HDMI cable, use any other HDMI cable in BluRay and TV and I would recommend to plug cable in another HDMI port in tv (if available) to solve this issue.
Make sure HDMI cable connector is plugged fully in both units, lose connection can cause No Signal display in tv any time.
Hope these info will help you.
Thanks.
SOURCE: i am trying to connect
This might seem a little out there but you have hit the source button and scrolled down to the correct HDMI input for the device? Also if you dont see the correct input when you hit the source button then in the settings you might have that particular HDMI connection turned off.
SOURCE: We received an LG BD 330 blu-ray player as a
That does ring some bells. Does the tv ever do this when you are watching anything else on the HDMI input or any other inputs, apart from the DVD player as the input source?
