It was working great until it just stopped and tripped the main power fuse then started flashing E5 with the fan symbol, i have cleaned the filters, had the main power fuse replaced, had the gas checked and that seemed to be finewhat could be the issue? and why would the fan symbol be fashing with E5?
SOURCE: I have a Fujitsu Split
Try to disconnect the supply from circuit breaker for 10sec. and "on" again, if it doesn't work you need at qualified technician for that problem.
SOURCE: LG C12AWR Air conditioner head fan not working
Check that the fanmotor can spin freely. If not, can be caused by seized bearing on left side of fanblade, or foreign object, insect nest stuck in fanblade. If however it spins freely, check that fanmotor is being supplied with voltage (you sound technically capable of operating a volt meter). If power is supplied, fanmotor is faulty and needs replacing. If no voltage, problem lies with the pc board. If you know someone who is capable let them check the relays on the board. Also you can check that all plug on connectors are making good connection.
SOURCE: AC not working
Try opening the front of the machine and check the circuit board has not got anything on it the could cause a short. I had the same problem but mine was a gekko that fried on my circuit board.
SOURCE: AC Fan doesn't blow cold air, frozen coil noticed outside, resetting power resolves temporarily
You need to call a reputable service technician. The freezing up usually is associated with a low refrigerant charge or low air flow. Check your return air filter and replace as needed.
