Amana PTC153B50AM Split System Air Conditioner Logo
Carla Holland Posted on Jan 04, 2013
Ptac153b50am not blowing hot air
Fan blows but only cool air can't find reset
Nathaniel Persson
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Dec 14, 2014
Nathaniel Persson
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
Helped
3085
Points
8
Have an identical unit. Replaced the heater core which has built in limit switches. Didn't fix. Finally fixed it by replacing the heater relays (small black boxes soldered into the circuit board). Can purchase at Digi-Key online for $4 apiece or buy a new circuit board for about $100.
5 Related Answers
Anonymous
  • Posted on Nov 05, 2008
SOURCE: Fan stops,but unit keeps running
maybe a motor or fan belt
acrman404a
  • 38 Answers
  • Posted on Jun 03, 2009
SOURCE: Rheem Criterion II air conditioner runs but it does not cool
Check air temp out vent should be approx 20 degrees colder than room temp if it is your unit is too small for the amount of space you are cooling.Rule of thumb 1 ton(12,000btu's) for every 400 sq ft of uninsulated space
Anonymous
  • 18 Answers
  • Posted on Jul 02, 2009
SOURCE: no cool air. blowing warm air
is breaker for condenser tripped---has it been running before -----is fan on outdoor ubnit running?
Anonymous
  • 614 Answers
  • Posted on Jul 19, 2009
SOURCE: Noisy Amana Quiet Zone air conditioner
The compressor sounds like the springs inside are bad. You can live with this are get the compresor eplaced if it is over five years old buy a new unit. Compressor will cost more than a new unit. Russ
Sparky2012
Sergio Shamshoian
  • 102 Answers
  • Posted on Dec 04, 2009
SOURCE: my ptac is not blowing hot air only blows warm air
freon is low or outside is very cold
1helpful
I have 1994 Chevy Lumina 4dr 3.1 Multi Point, Front W/D, F1, 6cyl. My air conditioner was blowing warm air @ 2mos ago & my husband added freon & a/c began blowing cooler air but, not as cold as...
You have a Freon leak because all the fittings, seals, coils rubber, compressor seals and entire AC system will need to be checked out by someone that can find the problem and resolve them or you will never get this fixed. A/C in cars get hot in the summer and cold in winter and all the seals dry out. The system needs to have all the air and moisture pulled out before any Freon in charged into repaires A/C unit or the system will not cool properly.That is the only way to resolve this Tammy, Thanks Sea Breeze
1helpful
2answers
AC blowing hot air one side & cool air other side
If it has dual zone temp. control it is most likely the heater control panel.
1helpful
2000 NISSAN 4X4 P/U A/C SYSTEM WILL BLOW COLD WHEN OUTSIDE AIR TEMP IS COOL, WHEN HOT OUTSIDE AIR BLOWS HOT.
your auxillary fan is not working. this fan is responsible for cooling the freon that is being circulated in your cooling system... check if there are any loose wires in front of the engine bay.
the auxillary fan is located right beside your radiator fan.
No water collected
check to see if the fan is blowing across the condenser. there should be warm air blowing out the back. if there isn't, the fan may need to be replaced so the heat exchanger can cool down. may be running too hot. also check the condenser in the front to see if the air flow is blocked with dust. if so, change the filter if it has one. if there is cool air blowing, the compressor may not be turning on.
1helpful
My FUJITSU FMV-720NU5/B LIFEBOOK has this problem of sudden shut off when it's getting hot. What could be the possible solution for this problem?
1.Temperature gets high if many programs work,specially programs which uses more graphic and processor. Disable/uninstal some un-important program you have installed.
2.Normally Fan processor should be cooling the processor, but sometimes we must check the heatsink, something might blocked the fan to run run faster if system overheat >>> tri clean the heatsink and fan up carefully. you might need an air blows to sucked/blows the dirt inside the heatsink.
[email protected]
2answers
The ac blows but it dosent blow kool fan works and its full of freon what should i do and if it blows kool it only blows kool at night
You have the system leak tested
Then have it evacuated & leaks repaired
& recharged
It only cools at night because it is low on refrigerant
& during the day it is so hot in the condensor
that it boils off refrigerant before the expansion valve
& doesn't cool the evaporator
No -- you can not add & polute the atmoshpere
I would think there may be air in there also
Can not work on it yourself
Hot spots on outside of Amana fridge. sxd22s2w model
if it feels like it's running hot check the coil to see if it needs to be cleaned,remove the bottom kick plate and look at the coil,the coil should be cleaned once every 6 to 12 months,also pull the fridge out,remove the back bottom panel,make sure the condenser fan is blowing and vac out any lint near the fan and compressor,also check the cover that you removed and clean that too.you might want to unplug the fridge while you clean back there so you don't hit the fan blade,wait 5 minutes before you plug it back in so the compressor can reset itself.there are gas lines that run through the frame of the machine,if the coil is jammed with dust and lint the machine runs hotter,this is how it cools off through the condenser coil and the fan blows the air around to help cool it down,if it runs hot then the freon will run hot and you could feel it on the frame and in the strip where the doors close together.you can buy a brush that you can push into the holes of the coil to pull the dust out or if you have a shop vac you can vac out as much as you can and then put it on blow and blow the dust out of the coil,just hit it with short bursts or the dust will blow everywhere.
Heater not working when on Heat but working when on Fan
is there a venting fan, that may be faulty not sending power to heat
Fan runs but blowing hot air. Thunderstorm reset some breakers. I did reset the two breakers inside the house and one unit working fine, upstairs unit fan running but blowing warm air only. Box out
Sounds like your Capacitor is bad, or you had a wire burn off compressor terminal or capacitor. Way you can check capacitor is take cover off and see if looks swollen. Make sure to turn off power before taking panel off.
Top Amana Heating & Cooling Experts
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
