Windsor SR12 Sensor Bagged Upright Vacuum Logo
Jotham Hatch Posted on Jan 04, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Windsor Sensor s12 and power shuts off after 5 min. of vacuuming. I'm wondering if it's overheating of if there is some other sensor that causes it to shut off.
After we let it cool off for a few minutes it will start again but only run for a few seconds.
Thatvacguy.com
Level 3:
  • Windsor Master 1,619 Answers
  • Posted on Oct 19, 2013
Thatvacguy.com
Windsor Master
Level 3:
Answers
1619
Questions
0
Helped
603685
Points
3345
Your Sensor most likely has an internal heat sensor that is shutting off the motor. Some vacuums install an external heat sensor with a reset button that you must push to re-start the vacuum. If your model does not have an external reset button it is most likely a sensor inside the motor. If it is defective the motor must be replaced to solve the problem. But first make sure the overheating is not being caused by a blockage somewhere or the bag is too full. Air must pass completely through a vacuum starting at the floor where it picks up the dirt through all the canisters, filters, bags, etc. and then is exhausted from the vacuum. Any restrictions or blockage can cause the motor to over heat.
That Vac Guy
Larry Tavlarides
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 01, 2020
Larry Tavlarides
Contributor
Level 1:
Answers
Questions
Helped
7632
Points
I'm looking at this Windsor Karcher that sometimes you can smell an electrical burn, but the armature and all looks good. However, the vacuum will shut off after about 10 minutes of running. There are no clogs and I had already installed a new power supply board. Thank you!
Robert V
Level 2:
New Friend:
  • Expert 110 Answers
  • Posted on Dec 01, 2015
Robert V
Expert
Level 2:
New Friend:
Answers
110
Questions
0
Helped
25129
Points
297
The Sensors are great machines as are the Versamatics. I've found that if the Sensor is shutting off then cleaning or replacing the "hygiene filter", the tall filter inside the bag compartment, normally fixes the problem, letting the motor "breathe" easier. The bag full and clog sensors wear out over time. I own two and those lights are constantly on.
brian
Level 1:
New Friend:
  • Posted on Feb 10, 2015
brian
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7632
Points
I have a question for you... my sensor s12 - the motor cuts in and out as the machine is moved from verticle to horizontal positions as well in the vertical position when pushed as far forward as possible.
I have changed the cord/handle no effect.
changed filters/bag no effect
pinched or broken wire?
kalsang
Level 1:
New Friend:
  • Posted on Jan 19, 2015
kalsang
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7632
Points
Hi Chris! question, we have couple of windsor S12 vacuum, but most of them as a same issue with Bad full and Clog light on, even we change new bag and clean all the host, but sill that red light come on and after sometime, vacuum itself shuts down automatically. any troubleshooting for this case. we cleaned the brush, filter, change new bag and clear all the host, but still same issue with red light on. need help badly.
thanks
2 Related Answers
Anonymous
  • 6 Answers
  • Posted on Feb 25, 2010
SOURCE: No Power to Windsor Sensor XP12
The Windsor Sensor vacs all have a removable handle.
The handle is inserted into a "socket" which has contacts to complete the electrical circuit.
The handle is held in place by a gray plastic lever.
If the lever is not pressed down completely, the handle is able to slide within the socket during regular use.
If the handle slides out far enough, the electrical connection within will be disconnected and the vac will have no power.
Simply lift the lever, pull up to remove the handle, and re-insert the handle fully, then press down firmly on the lever to lock the handle securely in place.
This is the first step to solve your problem and hopefully this is all that need to be done.
If this does not work, please repost here and I will help you all I can.
Note: I am a big fan of the Windsor Sensor vacs and find them to be easy to work on and a great vac all around!
Anonymous
  • 438 Answers
  • Posted on Apr 27, 2010
SOURCE: how do you change the belt on a winsor sensor s12?
Step 1. Remove the vacuum bag housing so that you are only working with the power nozzle or the bottom portion of your Sebo, this will make it much easier to work with. Turn the vacuum upside down, and remove only the 5 screws that I have circled in red:
Step 2. After removing the screws on the bottom of the vacuum cleaner, separate the top housing from the lower agitator housing, sometimes it may take putting a flat head screw driver in between the white and grey colored housing and prying them apart.
Step 3. You now have full access to the belts on your machine. It's most likely the belt that wraps around the brush gear rather then the belt that's attached to the motor that's gone bad. I have never replaced the motor belt in 8 years of servicing Windsor vacuums.
If you have any further questions on how to replace the belt, please feel free to reply to this repair by leaving your question in the comment section, I'm always more then happy to answer any question you may have.
Thanks again,
Chris Jones
goVacuum.com
Windsor S12 vacuum handle release not working pushed up handle won't pull out anyway to fix or adjust ?
Information and spares diagrams. You would have to disassemble and find the reason, but probably a spring became unhitched.
https://www.google.com/search?q=Windsor+S12+vacuum+handle+release+not+working
Where is the Yoke assembly located?? I'm taking advice on a bag light but cannot find the yoke??
Be sure that you have no clogs in the system and have fresh micro and exhaust filters. If you're having issues with a persistent bag full indicator on a Sensor S12, this is usually caused by a malfunctioning bypass valve. Moisture and even very fine dust (ash, drywall etc) can infiltrate the bypass valve causing it to foul. Replacement is pretty straight forward.
https://hproclean.com/products/86139100-bypass-valve
How to fix sensor s12. red light for bag stays on even when vacuum bag is not full and the vacuum is clear
You most likely will need to change the Yoke assembly. There is a sensor built in that gets clogged with fine debris over time. This will take care of the problem.
2answers
I have windsor s12 red light for bag is full is on and it's not clogged. what next
Check the line going from the bottom of the vacuum to the bag, it may be clogged. A coat hanger can help you clear any jams, but be careful not to puncture the duct.
The handle release on windsor s12 won't spring into place
You likely have one of two problems. Your return spring is broken, or your axle is bent. If your axle is bent, carefully inspect your chassis to be sure that the bent axle has not cracked or otherwise damaged the chassis. I have included a parts list as well as some links to these parts for your reference. http://windsorvacuums.com/partslists/s12_PARTS.pdf 2010 Axle Spring 86146570 windsor allstar javelin 5053 Windsor Sensor Axle 86137990 allstar javelin
1helpful
Windsor sensor vacuum lights flashing then motor shuts off
I've worked on these a lot. What I think you're explaining is the bypass flow switch which is a common failure. It's located in the base inside the auction side of motor housing...
Vacuum shuts off and on while trying to vacuum
check power cable for brakes and cracks, replace if need be..
1helpful
How do you change the belt on a winsor sensor s12?
Thanks again,
Chris Jones
goVacuum.com
3helpful
I have windsor s12 vaccum this one have brush up light on
The windsor Sensor brush indicator light will come on when:
  • Something stuck in the brushroller
  • Brushroller is worn and needs replacement
  • height is wrong (indicates a problem with height adjustment)
  • a bad circut board/sensor
more than likely your brushroller just needs to be replaced, very common.
Top Windsor Vacuums Experts
john h
Are you a Windsor Vacuum Expert? Answer questions, earn points and help others
