Cars & Trucks Logo
Anonymous Posted on Jan 04, 2013
How do I get instructions for a Walton high sleeper with desk and wardrobe
I have a Walton high sleeper with desk and wardrobe but no instructions can anybody help
tazandwill
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 23, 2014
tazandwill
Contributor
Level 1:
Answers
Questions
0
Helped
212
Points
0
Hiya did u manage 2 sort out an instruction book iv just bought a bed with no instructions so any help would be well appreciated thanks
1helpful
Competition between the Plastic Locker and Steel Locker?
Plastic locker is also known as plastic wardrobe or wardrobe or steel locker (ABS locker). With its unique material, moisture proof, rustproof, impact resistance, heat resistance, acid and alkali resistance and other advantages, plastic locker is widely used in all kinds of special places, such as swimming pool, gymnasium, university bathhouse, beach, fitness center, bath center, station, subway station, big industrial mining companies, department stores, supermarkets, libraries, stadiums, ski resorts, golf courses, and many other places.Using ABS plastic granules and steel casting mould, plastic locker is molded through injection molding of big machine. It has features of moisture proof, corrosion resistance, wear resistance, non-toxic, tasteless, gorgeous color and lustre, colorfastness, never rust and long service life. Nowadays many domestic Shanghai manufacturers, for the purpose of reducing cost, produce and sale of ABS lockers, most of which are made by recycled plastic with product quality far beyond that of real material ABS. Therefore when consumers buy this product, try to choose products of international famous manufacturers, especially imported from abroad.Using high quality cold-rolled steel plate, steel locker is made after shearing, punching, bending, welding, installation. Plate thickness is 0.6 mm (0.5-1.0 mm optional). Some steel lockers select high specification fusion welding, with smooth appearance. Steel wardrobe door chooses imported plastic powder electrostatic spray molding and it is disposed through nine severe procedures (hot water wash, pre-skim, skim, cold water wash, surface conditioning, phosphating, etc.) to strengthen the maintenance of appearance and protect it from being influenced by wet environment. It is equipped with label box, stainless steel handle, ventilation window, and pores to ensure the air circulation inside it. The luxury locker is attached with logo of lock and unlock. Patent design of clad door, with generous appearance, increases space. It is also equipped with internal dressing mirror and stainless steel clothes rail. Steel locker is suitable for various companies, hotels, campus, swimming pool, playgrounds, dormitories and other local locker room or storage room.Through summarizing the difference between the two kinds of locker, we know what kind of locker to choose in corresponding situation, and this is also very important for us.
Plastic Lockers ABS Lockers Manufacturer China Top Lockers
Where the wiring harness for the sleeper lights on top of the outside of sleeper on a kenworth aerodyn. 1998 w900l ? Thank you
Good question. Since most manufacturers don't give routing of harnesses, just generalization. Where they should be. You have to do what most of us do. Pull panels to find the short. Start at the light itself. Check for power and ground in the wire behind the plug.
How do you get to the expansion valve in the sleeper 05 w 900 studio
the expansion valve (TX valve) will be in the pipe immediately before the evaporator in the sleeper. To do any work on it will require the system to be pumped down before and after the work
2013 MACK Pinnacle
As all these plug ins will pull considerable power I would be looking for a fusible link near the battery or near the main fuse box. Contact Mack service centre for how the sleeper is wired and where the main power comes from
NEED ASSEMBLY INSTRUCTIONS FOR Z-LINE DESIGNS TRINITY COMPACT GLASS TOP COMPUTER DESK MODEL NUMBER SP357-1D
need instructions to assemble Z- line Trinity Glass compact computer desk?
How do I activate the phone/blue tooth device in my car
Go to dealer and ask for a instruction booklet is the best advice i can offer ,when i learnt about cars their was only 2 TV channels in B/W and radio caroline ruled the airwaves off the coast by walton on the naze
I need assembly instructions for kidspace metro mid sleeper bed
You have this question posted to the Car and Truck forum. Please post it in the proper product category so the right expert can help you
Lost instruction manual for MFI millborne triple pine wardrobe
This is a piece of furniture right? Are you looking for assembly instructions?
What is the right exhaust to use for a high compression setup on an h22a?
for exhaust, if you want stock looking then get a prelude muffler and have a shop make the piping the same size as the prelude exhaust (which is 2.25 i think?)
if you want sleeper exhausts then
get two 2-1/2" dynomax race bullets $27.95 ea. from summit. and a Magnaflow street muffler in your style of choice. $120?? get 1 race bullet welded in just behind the cat or header and the other back before the first 90 degree bend and the muffler welded on.
This is the best way to make a super sleeper. Magnaflow's are super quiet.
Race bullets act as resonators. they are only available in 2.5" in/out but thats ok.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
