HP Hewlett Packard LaserJet 3000dn Printer Logo
Posted on Jan 19, 2009
Hp laserjet m1522nf 10.0000 supply memory error
The printer states a 10.0000 supply memory error and will not print as it has in the past.
  • 2 more comments
  • Anonymous Jan 27, 2009
    Mine is doing exactly the same: "10.0000 Supply memory error"
  • Anonymous Feb 06, 2009
    Hp41522nf 10.1000 supply memory error
  • binben Feb 19, 2009
    I have the same error and some printing job automatic restart, take alot of paper. When print a mail merge in MS word, it also got problem
  • Anonymous May 17, 2009
    i am getting error of 10.0000 supply memory error.
    plz sort out it.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 23, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
38905
Points
21
Had same problem. It turns out I didn't remove all plastic caps from new cartridge (mine came with orange-color). Once I did that, problem solved.
  • Brianbaumer Apr 11, 2011
    Thanks abunch, I spent over 2 hours on the phone with the smart peopel in INDIA and they could bnot fix the problem, awesome thanks a bunch I did what you did and it is all good!!
  • Kevin Mast Sep 19, 2013
    I too had the same problem and tried all the unplugging and cartridge removal tricks, but the error kept coming back. The post from totalcomp18 solved the problem. There is a orange square plastic cap with a tab that goes around a sensor. I pulled it off and all reinstalled the cartridge. Let the machine reset itself, and all is OK. Thank You.
Anonymous
Level 1:
New Friend:
  • Posted on Dec 21, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
38905
Points
14
Suddenly my toner finished. I changed original HP toner. but I found an error 10.1000 supply memory error. I checked the toner I had removed all orange tap completlly I removed toner twice or thrice. But Error was same. Then I switched off My printer HP 1522nf and remove and re-installed toner. This time error did not come. I like sharing my exepriences.
  • carlosnewmoj Jan 16, 2011
    I got an 10.1000 memory supply error. I removed an orange cap still on the cartridge and now theres no error.
    Thanks for the solution!!!!!
  • bobba Louie Feb 14, 2011
    Thanks for the tip, I found the same thing. The setup shows it, but I'm used to pulling a single orange tab from the cartridge before installing it, so I overlooked it.
Getta Biggerhammer
Level 1:
  • Contributor 5 Answers
  • Posted on Jun 04, 2009
Getta Biggerhammer
Contributor
Level 1:
Answers
5
Questions
0
Helped
58347
Points
23
We had the same problem. The error has to do with the cartridge. Take the cartridge out, clean the contacts, put it back in.    Buy another original cartridge to replace it.
  • cupid009 Jun 02, 2011
    I had the same problem. I removed orange cap from the cartridge and it works fine now.
    Thanks for your help guyz......
Anonymous
Level 1:
  • Posted on Feb 02, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
38905
Points
Http://www.all-laser.com/cgi-bin/webc.cgi/error-code.html#ERROR10
Anonymous
Level 1:
New Friend:
  • Posted on Dec 23, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
38905
Points
Error in hp laser jet printer m1522nf
2 Related Answers
seeker5211
Seeker5211
  • 1089 Answers
  • Posted on Jun 03, 2010
SOURCE: Hp laserjet m1522nf 10.0000 supply memory error...
Are you using HP toner? Try reseating the cartridge. If it's still getting the error, replace the cartridge.
Dadofmykids
Andy Brasfield
  • 25 Answers
  • Posted on Apr 07, 2009
SOURCE: hp laserjet m1522nf 10.0000 supply memory error
Try another toner. Most likely the chip on this one is bad.
Supply memory error
There is a protective plastic clip over the cartridge chip. Remove the orange plastic and it will quit giving you the supply memory error. Refer to figure 6
Supply Memory Error' Message Displays on the Control Panel
Or Still having Problem Then follow Us For
HP Support
1helpful
Supply memory error color
A "supply memory" error is usually caused by a bad toner cartridge. Each cartridge has a chip that is read by the printer.
Try reseating the cartridges.
Did the error occur after you swapped out a cartridge?
1helpful
3answers
Hp laserjet m1522nf 10.1000 supply memory error
Most likely the Orange Clip that surrounds the sensor contacts on the front edge of the cartridge was not removed. Open the machine, look at your cartridge, make certain that any clips or protectors are removed, clean the contacts if in doubt and reseat the cartridge... your problem should be solved.
I am receiving error 10.1000 supply memory error
10.1000 Supply Memory Error
A specific print cartridge has a missing elabel.
Reinstall the print cartridge.
Turn off and then turn on the product.
If the problem is not solved, replace the cartridge(CB436A)
2helpful
What is 10,1000 supply memory error with hp
If the problem is not solved, replace the cartridge.
8helpful
Hp laserjet m1522nf. when you print it states scanner error 5 turn off then on
See my tips section for the solution to this. This error is covered by HP and they will repair at no charge for almost all M1522's ever made.
2helpful
I have a problem with my HP ColorLaserJet CP2025 the problem is that it show in the screen (10.1000 supply memory error) so that i cannot print any document..
Most likely this error is caused by using a remanufactured cartridge. If it is a new, genuine HP cartridge, you can return it to the dealer for a new one.
3helpful
Error memory 10.1000
This means that a specific cartridge has an e-label error.
The solution is to:
1. Reinstall the print cartridge.
2. Turn off and then turn on the printer.
3. If the problem is not solved, replace the cartridge.
1helpful
2answers
k24674
Grand Canyon Tech
Grand Canyon Tech
