Gun gasses up, fan woks but doesnt fire when trigger is pulled. at first was intermitent then stoped firing altogether. there is gas there and fan is working but not firing
SOURCE: Can I use paslode roundrive nails in a Hitachi NR90GC Gas Nailer
Yes, BUT the paslode Round drive nails and known to cause driver jamms due to the excessive paper used in the spacing of the nails.
SOURCE: My hitachi nailer is not firing. Sounds as if the
This sounds like the nailer is not in the "home" position. Usually this is due to a leak in the o-ring or a lack of lubrication that is not allowing the plunger to return to the home position. If you can get an O-ring kit, I'd replace all of the orings and make sure that everything is properly lubricated. Should that not fix the problem, the next likely candidate would be the trigger assembly itself. The O-ring kit will run about $20 or so and a similar amount for the trigger assembly.
Hope this helps,
Dan
i have exactly the same problem it is a new gun only used it a couple of times. some times if you hold it down it can take 5 seconds before it fires a nail if it fires a nail
