AFFINITY COIN TRAP 1. Unplug the unit. 2. Tilt the unit up to where the front feet are in the air and the back feet are still on the ground. Please make sure the unit is propped up safely. 3. Now that the unit is propped up look inside on the bottom right hand side there is a black looking accordion piece. This is the coin trap. 4. Clean the drum out with as much water as possible and have towels ready. The next step you will have the remaining water come out. 5. At the top of the coin trap where it is attached to the drum is a silver spring with a silver screw. Loosen the screw and wiggle the coin trap down from the drum. 6. Reach inside the coin trap and clean what is inside of it out. 7. Put the unit back together following the same steps backwards
Thanks for your post, friend!
I understand that you looking for steps on how to clean the coin trap on your Frigidaire washer. Here are the steps to access the coin trap.
· Assure power has been disconnected to your appliance.
· Tilt the unit up to where the front feet are in the air and the back feet are still on the ground. Please make sure it is tilted up safely.
· Look inside on the bottom right hand side there is a black accordion piece. This is the screen trap or coin trap.
· Have towels available with you because any access water will come out.
· At the top of the coin trap where it is attached to the drum you will notice a silver spring and screw. Loosen the screw and wiggle the coin trap out.
· Clean the trap and follow these steps in reverse to reassemble your washer.
Best of luck! -Matt
