SOURCE: Beeping Dryer!
Hi, the the glowing igniter does not functioning need to replace / the sensor tip will send signal to computer box that the glowing are busted.
SOURCE: Won't start, beeping sounds
sounds like the door switch might be an issue,, does teh tub light go on /off as you open the door??? if not try manually pushing the switch in a few times.
SOURCE: Whirlpool Duet Dryer WED9600 Beeping during drying
Dear Customer
Please perform the following
please rate this,thank u
SOURCE: Dryer turns off after 30 seconds and beeps six times (over and over.....)
there is a moisture sensor by the lint screen, that could be defective.
SOURCE: My Frigidaire FEQ1442ES1 dryer has started to beep
When I read to manual, it said it was the lint. I use a paint brush to brush the lint off and usually the beeping stops.
