Question about Maytag 24 in. MDB9750AW Dishwasher
Maytag Quiet Series 300/Dishwasher leaving gritty stuff on dishes
When we use the dish washer the dishes come out worse than when we put them in. The dishes, especially on the top, have grit stuck on them. It's incredibly hard to get it off once the dry-cycle has completed and "bakes it on".
Any...I am looking for some help on how to stop this from happening.
Thanks
Cheri
  • 1 more comment
  • effiejane200 Jan 19, 2009
    I have the same problem and use the expensive dishwashing detergent.
    -Debbie
  • staceyhfos Jan 25, 2009
    Please let me know if you figure this out! It seems to squirt the grit up inside the glasses on the top rack so the inside bottoms have grit baked on, and other items have grit on the outside, so I can't isolate where it's coming from. I use Cascade with Dawn lemon scent. My dishwasher was recalled with the jet dry problem but I did not install the part they sent me to seal it off--I was a little offended because I thought they were sending a part to fix the problem. Could that have anything to do with this?
  • andyo3000 Feb 01, 2009
    We are having the same problem. We typically don't use Jet Dry or the drying button. We do have hard water and the softener was down for a bit but it's hard to believe it would lime up that quickly.
    Sounds like Maytag has a quality control issue. They should get on top of this.
My model is simillar Cheri's. Every couple years I have to remove the plastic spray bars. They are held on by a simple torque screw. Once removed you will see debris plugging many of the holes. I have found this on all 4 of my spray bars. This debris prevents the right amount of water in the wash and rinse cycles. The upper spray bars seem to be the worse. This explains the trouble most folks have with glasses in the upper rack. Also check the docking station. You will fiind it along the back wall of your unit. The plastic tubes on the backside of each rack will slide into a hole in the docking station. After a few years the rubber seal in the docking station will be worn away. Once this happens, it prevents the correct water pressure to the upper rack. The replacement part snaps into place and cost about $25.
Posted on Apr 04, 2010
    New Friend:
I have found that the top spray arm can become coated with food residue in all of the parts that are supposed to be loose enough to let the arm rotate. I removed the arm by releasing the brackets that hold it in place and using the correct torque screw thingie removed the sprayer arm from the bracket assembly. As I disassembled it each fitted plastic piece was coated with a white gummy and gritty substance. I'm thinking it is probably mostly paper labels from jars that my better half is too lazy to soak off. I removed about a tablespoon of this stuff that was gunking up the parts and then ran the dishwasher with a cup of bleach. Haven't been brave enough to disassemble the bottom spray arm/pump assembly yet but this has helped a lot!
Posted on Jan 30, 2015
SOURCE:
I use siemens dishwasherand recently noticed some grit like substance left on my dishes etc after every wash
There should be a screen under the spray bar. Make sure that is clean. So "grit" is not recirculated in the wash cycle. Is "grit" showing up in your house water elsewhere? Check with clear water glass. Also consider testing with a competitive wash compound to see if there is any difference. A sample or from your friends.
Apr 14, 2015 | Siemens Dishwashers
Grit in clean glasses and on dishes
Mary do you have a water softener? If so, only use 1 tablespoon of dry dishwashing detergent per wash. Don't use tablets or liquid soaps. Too much soap will wear down the items you wash, leave streaks and pock your dishes. That might be what the sandy grit is. Also, to get rid of the grit inside of your washer you can buy a special dishwasher cleaner at almost any hardware store. Always try to use a rinse-aid. Make sure your drain filters are clean. Hope this helps. Jewels
Mar 15, 2013 | Dishwashers
Food gets stuck on dishes especially in the top rack.
There is a waste filter in the bottom under the lower spray arm that needs to be cleaned periodically. If you are not cleaning it, it may be redepositing food particles on your dishes.
remove and clean the filter, and see if that helps.
Nov 21, 2010 | Bosch 24 in. SHU66C05 Stainless Steel...
My 5-year old Bosch dishwasher leaves a somewhat fine grit on dishes? especially obvious on the inside of glasses. I use only Cascade detergent, use a rinse aid, don't overfill the machine, and always...
I have the same problem with mine!! It's 6 years old, and I'm running loads of dishes through twice. Even that doesn't help! And I rinse the dishes too, so I have no idea where all these "crumbs" are coming from. Will check back for updates. Hope to get this problem solved!
Oct 01, 2010 | Bosch 24 in. SHU6802UC / SHU6806UC...
Why is my dish washer leaving food on my dishes that i loaded rinsed off?some dishes come out dirtier than i put them in there.
It is almost always because you have blocked the hole where the sprayer goes up through the middle of the dishwasher. If it cannot pop up the dishes will not only not clean, but the food will just deposit onto the dishes especially the upper rack.
Sep 30, 2010 | GE Crock Pots & Slow Cookers
Kenmore Dishwasher not cleaning dishes - especially top rack.
put a pump kit in the dishwasher..and the water coming up is a house drain problem
Aug 06, 2009 | Kenmore Elite 45986 Front Load Washer
Dishes never come out clean
Sounds like not getting sufficient water. Replace water valve if that's the case.
Nov 14, 2017 | Whirlpool 24 in. Built-In Dishwasher w/...
Dishes do not come out clean?
is the salt container cap damaged or loose? is the rinse aid topped up? if all ok then are you scraping most of the food from the plates, this can cause old food to mush, pulp and leave grit on dishes.
Mar 18, 2009 | LG LDF6810ST Stainless Steel Built-in...
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 | Dishwashers
Maytag 24 in. MDB9750AW Dishwasher Logo
2,195 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Mike
Marvin
Marvin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
