My newly bought telefunken personal video recorder 500GB Hard Drive Twin HD Tuner suddenly stopped working. Yesterday, it worked fine, but when I checked it today I noticed that it didn't turn itself off after recording as usual. It seem to be on all the time and I couldn't turn it off, the remote control didn't respond to any selection, couldn't exit, menu didn't respond, in fact, nothing responded. I changed the batteries thinking maybe that was the problem, but it didn't make any difference at all. I simply couldn't turn the unit off, nothing seem to work no matter what button on the remote I selected. The only way to turn it off was to unplug the cable, but when I plugged the cable back again, it was still showing the unit as on, without doing anything. I have only used this item for about 7 weeks, and am very disappointed. I live on the Gold Coast, Australia.
SOURCE: DMR-E80H Remote stopped working
There is a section in the manual about resetting the remote. It is a simple fix You can go to the manuals on Panasonic.com to find the methods of the madness
SOURCE: Memorex MVD4544 VCR will not record
Take the unit back to the store and exchange it for an other unit of the same. The likelyhood of two units not working is very slim, and good luck with your new unit.
SOURCE: LVW-5005X DVD Recorder setup tv tuner
You have the wrong firmware,or cd is corrupted.These Liteon recorders have had some issues with the timers.The 5005xa can actually be transformed into the Ilo R04.Look on internet the Wizard has free firmware for your unit, look for iLO R04 which is almost identical to your unit.
If the remote is broke they are easy to replace ,if the recorder is a 5005xa the remote is a clone to ones used in the iLO RO4,used ones can be bought on Ebay for $10 to $20.If it is 5005XSA use the Liteon Rm 51 remote.The Gateway AR 230 recorder and some of the Akai remotes are clones to the Liteon5005XSA remotes.
New updates available for service issues such as freezing and start up/ recording issues (firmware 2011) are also available from the DGTEC website.download and put on usb drive
Please update software first before replacing hardware...
From DGTEC Website Software Upgrades page: -
Click on the relevant link below to download the latest software update for your DGTEC product. For further help and assistance, please access the DGTEC Call Centre via the Support page.
Obsolete Products
* DG-FV500PVR Upgrade (zip file 4.3Mb)
* DG-HD6760 Upgrade (rar file 2.3Mb) Upgrade instructions DG-HD6760 (25Kb)
New Products
DG-HDMP1080
DG-HDMP1080P
DG-HDMP1080TT
DG-HDMP500TT
DG-DABVPR1TB
DG-DABPVR500GB
DG-HD2104AND
Models
DG-FV500PVR - 500GB HD PVR WITH TWIN TUNER (FREEVIEW)
DG-HD6760 - HD SET TOP BOX WITH USB RECORDING
DG-HDMP1080 - HD MEDIA PLAYER
DG-HDMP1080P - WIRELESS HD MULTI MEDIA PLAYER / STB
DG-HDMP1080TT - HD MEDIA PLAYER WITH TWIN TUNER
DG-HDMP500TT - (NEW MODEL RELEASE)
DG-DABVPR1TB - 1TB HD PVR WITH TWIN TUNER WITH INTEGRAT
DG-DABPVR500GB / DG-DAB+500PVR- 500GB HD PVR / TWIN TUNER WITH INTEGRATED
TV-6600 BAUHN UNIT- 500GB HD TWIN TUNER PVR
GG-HD1200PVR- BAUHN UNIT WITH TWIN TUNER
Note: - Master Override Password 1973
Instructions:
Read instructions carefully before commencing. Software needs to be carried out while the PVR is cold. Go to "Telefix" website and select "Service Guide" or "Download Service Manuals" and download software to a location on the PC Hard Drive.
Unzip file and copy "usb.upg" software onto a blank USB Memory Stick.
Plug USB Stick to USB port of PVR
Connect Power to PVR and switch on so that that the booting process commences.
Press 'Menu' button and scroll left or right by using the arrow buttons to find 'Installation' then press OK to select.
Note: PVR may freeze and not allow selection. Several attempts will be required to enable selection. If problem persists, switch OFF PVR to allow it to cool down then try again or use the alternative method.
Alternative Method
1a. Disconnect mains power.
2a. Plug USB Memory Stick to USB port.
3a. Press and hold the CH down arrow button on the unit and then connect mains power.
4a. When the display starts counting down release channel button and the upgrade interface will appear on screen.
7. Scroll down to 'USB Menu' by using the arrow down button then press 'OK' to select.
8. Scroll down to 'USB Upgrade' by using the arrow down button then press 'OK' to commence software update.
· Note: - Please do not shutdown PVR or remove USB Stick during the update process. When the update is complete the PVR will power down and reboot again as normal.
Once the update has completed, reset the PVR by restoring back to Factory Default.
Press Menu ? Installation ? Factory Default ? enter password 0 0 0 0 ? Select 'Yes' ? press OK to rescan channels.
Check Software Version, Press Menu ? Installation ? Version Info ? OK
