BATTERIES ARE FULL CHARGED WITH EXTERNAL CHARGER. WHEELS REVOLVE ONLY WHILE POWER IS PLUGGED INTO THE ONBOARD CHARGER BERT SELLS
Hi. This is just a thought but have you tried putting the batteries back on the scooter and putting a volt meter on the batteries to get a reading when the lever is pressed on the scooter. Batteries can display as being fully charged (+12 volts) but often fail under load, meaning that as soon as you press the lever, the voltage will drop right off. If this happens, it is more than likely that your batteries are to blame.
Hope this helps.
SOURCE: Having trouble with a 3-wheel Pride Mobility
Check that it is unplugged from the charger. Then check the freewheel lever to ensure it is in gear by placing it out of gear first, then placing it firmly in gear. Do this while the key is OFF. Wait three seconds, then turn back on and it should go.
If it doesn't, and you are sure it's in gear and unplugged from the charger, you should be getting a fault code flashing on the charger display. Consult your owners manual to determine the fault and proceed as recommended.
Here's a link to the owners manual if you've lost yours. Good luck.
http://www.pridemobility.com/pdf/Owners_Manuals/US_Scooter/US_Victory_om.pdf
SOURCE: instruction manual for pride mobility sonic & celebraity scooter
Here is the link to all pride manuals for power mobility.All files are .pdf and searchable.
http://www.pridemobility.com/resourcecenter/Downloads/Product_Owners_Manuals/product_owners_manuals.asp
SOURCE: Pride Legend scooter won't hold charge
check the wiring from the batteries as a wire could have come loose.
Regards
GeWiz
SOURCE: Pride Rally 3 Wheeled Electric Mobility Scooter manual
DO not ask FIX IT ALL THEY WANT IS MONEY
SOURCE: The Pride GoGo 4 wheel scooter does not move
Hi. How many beeps between pauses? This is a fault code.
A couple of problems might cause this fault. Is your free-wheel lever in the correct place. These levers operate a switch, that tells the controller that the brake is disabled, this stops the controller from driving the scooter with out brakes.
Might also be caused by a stuck brush in the motor. This is usually caused by the caps that hold the brushes in, not being tight enough. Check the brushes, make sure they slide in and out smoothly, retighten the caps. Be carefull because these caps can crack easily.
Good luck. Neil.
MORE INFO ON MY PROBLEM. I CHARGED BOTH BATTERIES WOTH AN EXTERNAL CHARGER AND TESTED WITH A VOLT METER, BOTH WERE FULL CHARGED. THE WHEELS FAILED TO TURN. I CONNECTED POWER DIRECTLY TO THE SCOOTER AND TRIED THE FOWARD AND REVERSE AND THE WHEELS TURNED. I'M AT A LOSS. THANKS, BERT
