I have had my oceanic geo 2 for a year and a half and the battery just died. I replaced it myself and the first bAttery I put in died within as week. Fund that strange so made sure to get a lithium battery second time around and my watch is telling me the battery is low? Is this a common problem or is my watch ruined?
SOURCE: After full battery drain, no function
Hello FixYa,
How I solved the problem ???
Read my former post again.
I thought this could help you with your troubleshoot database.
Ragards, Marc
SOURCE: Mens Relic watch stopped working after battry change
I suggest that your watch has an oxidized contacts and electricity can not reach the movement.
Do as folloes:
Take out the batttery,
Clean (scrape) all battery related contacts till they are shiny (use hardened steel needle for that),
Use the dust blower to get rid off any tiny dust and dirt particles after cleaning,
Refit the battery back.
Now your watch should work again.
If all written above do not help, then there is a problem with your watch and you will need the help of the watchmaker.
Do not forget to rate, please.
SOURCE: beep and chime will not work
I think there would have been a minute spring coming from the back of the watch module to the backplate of the watch - this spring carried a vibration / beep which echoed off the backplate. Chances are you have damaged this spring during battery change - as i did with my gShock. Basically it's nackered!
SOURCE: Second request for help as to why my watch keeps losing time.
bad movement, get a refund or replace the watch
