Have not been able to use blue Ray player or other devises Only two ports appear to be working normally. the TV out and the VCR Port work fine but others I get no signal reading. I am currently using the VCR port to watch cable or Blue Ray by switching the HDMI cable. Any Ideas?
Went thru the menu ports were assigned correctly, no change in operation. I have heard about HDMI boards having problmes but thought that the problem would take out all ports and not be selective.
You're right, usually it's not just one or two jacks. I looked at the schematics and don't see anything specific to those jacks that would cause your problem. Unfortunately, replacing that board would probably cost you more than the receiver itself. Have you looked in the owner's manual to see if there is a factory reset that can be done? This sometimes fixes some wierd problems.
usually you can reset these units by holding down the vcr button and pressing the power button. CLEAR should show up on the display.
I have done the reset and it had no effect. I believe that the easiest and cheapest way out, is to purchase a new receiver. I am currently looking at one of three Onkyo 606, but worried about the heat problems, The Sony STR-DN 1030, which appears to be best for my setup or the Denon 1916, has more hook ups but does not have the WI-FI as the sony does.
