SOURCE: On rinse cycle, water is pouring out of the
Check the hose from the detergent tray to the drum to make sure that it is free from debris.
First take the top off by removing 2 screw in the back(Top right and Top left). Slide the top off and underneath the tray, feel around the tube to see if there is any blockages. You may have to pull the hose out.
SOURCE: Hoover Nextra washing machine - water backing up
If this is a front loader see that u use only washing powder for FRONT LOADING MACHINES. Also possible your detergent drawer is clogged with old dry detergent. Pull out the drawer and clean with tooth brush. Things shd be fine.
SOURCE: water remains in detergent drawer
bpkaplan - did you find a solutiion? I have the exact same problem with my LG Tromm WM2477HW front load washing machine. It is about 2 1/2 years old.
SOURCE: water is leaking out of the detergent drawer. It
i would say the outlet from the bleach area is blocked clean out drawer unit
SOURCE: water is pouring out of my dispenser drawer
I have read other folks say that this has happened to them when a sock or wash cloth gets stuck behind the rubber seal of the door. There is a pipe that drains the water from your detergent tray and it may be clogged with a sock. Try feeling around behind the rubber seal in proximity to the detergent tray and see if there is a piece of clothing stuck in the pipe that drains the detergent tray. Also remove the tray and check the pipe from that end too.
Testimonial: "Thank you I took the tray out and checked. I did not find anything so I poured hot water in the tray with some bakingsoda and vinegar.. it fizzed and then 10 mins later... it drained.."
