IBM Lenovo ThinkPad T400s Notebook - Core 2 Duo SP9400 2.4GHz - 14.1" - Black (2808DHU) Logo
A
Anonymous Posted on Jan 03, 2013
0210 stuck key 52 - IBM Lenovo ThinkPad T400s Notebook - Core 2 Duo SP9400 2.4GHz - 14.1" - Black (2808DHU)
5 Related Answers
Anonymous
  • Posted on Jan 28, 2010
SOURCE: i have error 0210 stuck key 01 on an IBM
My key R is stuck. And some some letter keys become numbers once I press them
Anonymous
  • 111 Answers
  • Posted on May 04, 2010
SOURCE: error 0210: stuck key 01
I assume its a laptop. laptops some times get stuck keys, meaning one of the keys has not fully released after it was depressed. I recommend getting some compressed air in a can and give it a good cleaning. there might be something stopping git from popping back up. then give the keys a little work out. just mash the keys a bit. then turn it back on. if you still have an error, then you might want to consider replacing the keyboard. if you don't, it will not harm you pc in anyway...good luck
Anonymous
  • 10406 Answers
  • Posted on Mar 08, 2011
SOURCE: how to fix an error
One of the keys on the keyboard is "stuck" in the "down" position, so that it keeps sending the same character. Quickly press/release each key, several times, to see if you can "unstuck" that key. Or, replace the keyboard.
Anonymous
  • 11 Answers
  • Posted on Jul 11, 2011
SOURCE: ERROR 0210: Stuck key 7B,
if this Problem before windows you need to reset keyboard cable anf if the Problem still you need to replace the keyboard
else if the Problem after windows just repair the Windows
Anonymous
  • 95 Answers
  • Posted on Jul 20, 2011
SOURCE: ERROR 0210: Stuck key 7B Press
There are issues with the ThinkVantage Button at boot as it doesn't do what its suppose to. Just use the F1(BIOS Setup), F11(pre-boot/recovery area) and F12(boot device selection).
Just a reminder to practice press and release when pressing a button. We sometimes get impatient and do a key hold down for a while rather than multiple press and release.
I hope this would resolves your ERROR 0210: Stuck key
Error 0210 stuck key 69 can someone tell me what it is
My guess is it is a programming glitch of the ALT key correctiable by BIOS modification rather than physically addressing. Such fixes are tried at your own peril and without guarantee of working (or even the computer working) after such.
https://aatayyab.wordpress.com/2019/12/19/when-a-key-on-a-computer-keyboard-gets-stuck-keyboard-codes-and-their-hex-scan-code-values/
https://answers.microsoft.com/en-us/windows/forum/windows_7-hardware/very-odd-0210-stuck-key-error/3885128d-6bb7-4442-a669-73b14bf58bff
That said, I would be awfully tempted to try an alternative keyboard (a rather dodgy idea if it is a laptop).
Error 0210 stuck key 3a
You going to need to find a new keyboard for this unit. Try ebay.com you might get lucky paying $20 or so..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
1helpful
Machine has an error 0210 stuck key. Not sure what my daughter has done to her machine- can you help?
Machine has an error 0210 stuck key. Not sure what Problem with the Fujitsu Siemens LifeBook T3010 Tablet P
0210: stuck key 2B
Find a replacement keyboard for your model online, and/or have a local computer shop install it (or order and install it) for you.
I have error 0210 stuck key 01 on an IBM
6helpful
Error 0210: Stuck Key 01
This is a system board POST/BIOS error code (nothing todo with Windows). The ERROR 210: is a standard POST (Power On Self Test) errormessage that indicates an error with the keyboard. The error condition is thata keyboard scan code was received from the keyboard when none was expected,after the keyboard was reset. If this occurs most of the time when you power on yoursystem, then it indicates that a key is sticking down or the key mechanical orelectrical parts are broken. Sometimes blowing out and cleaning out around thekeys will resolve this problem. Otherwise, you need to replace your keyboardwith a new (or at least a working) one.
6helpful
2answers
ERROR CODE "0210:KEY STUCK 39
I got the 0210 stuck key error on a Lenovo Thinkpad T61, pc would not bootup, made sure keyboard was connected and cleaned with aircan and then went into bios and via F1 on startup, then went to CONFIG then to Keyboard/Mouse then I disabled the TrackPoint. Boots up fine now but the red nipple mouse is disabled due to action mentioned above. Looks like a warranty fix for Lenovo since this is a newer laptop. If it was out of warranty i would just skip using it and leave it disabled. The trackpad works fine.
Top IBM Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
