Compaq UPS T2200 XR UPS System Logo
Posted on Jan 19, 2009
Battery voltage not known for UPS-DELTEC PRR 2200i
UPS, Make- DELTEC,
Model- PRR2200i,
Seial No.- A00211378,
Part No. 163760-003.
What is the battery voltage, is it 24 volt ot 48 volt?
all-is-info
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Jun 30, 2009
all-is-info
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
Helped
5097
Points
10
It uses 4x12v @ 26AH batteries in series, making a total of 48v (more like 52v if charged).
Manual for deltec power rite max prm700A
you can download the user manual on their website.
How do I recycle my dead PowerRite Plus 360 UPS? Or can it be recycled?
Most cities have local recycling centers where you can drop off paper, plastic, etc. They usually have something set up for electrical components like VCRs and batteries. The PowerRite Plus was an old Deltec model. Deltec was acquired a few times and is now belongs to Eaton. If you are looking for a new UPS, you can participate in the UPSgrade program which includes recycling your old UPS: eaton.com/upsgrade.
How to install battry in prr200 deltec ups
They are 12v 22AH SLA batteries. They are wired in series. The neg runs to the board, the two positive wires run to the fuses at the side of the cabinet.
-Phil
I have a UPS DELTEC, Model PRR 2200i. I want to know the battery voltage, is it 24 volt or 48 volt?
Sir, just open the ups, and you can see the battery inside. after you open, pull out the battery, then look for the voltage rating, it is located on the battery itself
Good luck,
Battery voltage not known for DELTEC PRR 2200
For deltec PRR2200i you got 4 pcs of 12 volts batteries and it was just connected in series
Power failure
the smart up 2200I, can not on again, each time I try to on it, it use to show a prompt light as if is about to on, how can I solve the problem?
COMPAQ UPS MAKE DELTEC MODLE PRR2200
If you replaced the batteries, and the +ve wire touched the body you will short out the batteries with possible battery death depending on how severe and for how long the short was.
You should not have harmed the UPS unit at all, not even blown the fuses.
2helpful
3000 VA UPS Service Manaul of Fiskars Power Systems Make
I have the same PCB on my Deltec PRR2200i. I at least know a few things about the circuit now. I had 11 transistors explode on mine and am replacing them now. Sadly I have not managed to track down a circuit diagram.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
