I can't change the day of the week in my casio worldtime watch 3198, i follow the instructions on the manual but it does not give me the option to change the day.
SOURCE: how to use a casio
Which model is it exactly? Maybe you can find the manual here: http://safemanuals.com/brand-user-guide-instructions-owner-manual/CASIO
Or you can try looking for it in CASIO's site. Usually the manufacturer have their manuals for download in the support page of the site.
If you can't find it, tell me the model and I can try it.
Best luck!
SOURCE: casio sport STR-900 watch
How to set the solar power time change, my watch has remained with the same time; and not one hour ahead (spring forward) ?
SOURCE: I have a Casio Wave Ceptor watch, model 3363 wva
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please.
SOURCE: Casio Digital Watch 590 W-59. Please
Click on the link below to download the manual for the Casio 590 W-59. Inside this manual will show you how to reset the alarm and time:
http://www.digitalwatchlibrary.com/images/casio_manuals/590.pdf
http://www.digitalwatchlibrary.com/DWL/1work/casio_w-592/
SOURCE: Casio 1170 ATC-1200 watch needs to have batteries changed
I'll post in case somebody still needs this. This is the general
procedure to switch the ATC 1200 from meters to feet. You can also
switch the ATC 1200 (1170) from C to F. This is very helpful if you
change the batteries and the watch gets reset to meters.
Also note, when you pull out the two batteries, you may not get the
watch to come up. This is because of a race condition when the watch
gets power. To fix this, look for the AC mark on the inside of the
watch. Under this marking, in a little space to the left, are two
copper pads. Short this out with a small screw driver to get the watch
to ground zero.
To fix the Metric measurements:
1. Go to the home screen on the watch. This is when the the 3 letter
abbr for the day is at the top. Also, if you cycle the mode button, it
is the screen where the final beep is "high."
2. Then press the "memory" button, which will take the home display to
the data screen. This shows current time, pressure and temperature.
3. Hold down the adjust button, until the set screen comes up.
4. Tab the mode/select button on the watch until you get a flashing C. Then press the memory button to toggle to F.
You can adjust all the measurements from this screen.
