Harbor Freight sells a low cost watch wrench but in a Robinson Crusoe situation you can CAREFULLY use square nosed needle nose pliers(Lowes or The Home Depot won't object if you try out one of theirs); hold watch in wash cloth to protect your hand, put the square blades in the watch back indentations and slowly turn with maximum pressure, after it opens use a quality Japan Maxell SR621W silver oxide, do NOT use a China alkaline version as they leak and have less run time. Use a Q-Tip with light Vaseline around the sealing edges when reassembling. Sincerely batteryBob
SOURCE: watch problem
take out the battery and clean under it and the area it is supposed to be settled in.Clean with rubbing alcohol.
SOURCE: Casio spf 40 Module 2273
Your Watch is in Auto or demo mode. Hold down the "Mode" button for 3 - 5 seconds and it will return to time keeping mode.
Cheers,
Murray
SOURCE: My Casio watch Battery was just changed now I can
mcdevito75 here, Return to where the battery was changed, for adjustments.
SOURCE: Casio 1170 ATC-1200 watch needs to have batteries changed
I'll post in case somebody still needs this. This is the general
procedure to switch the ATC 1200 from meters to feet. You can also
switch the ATC 1200 (1170) from C to F. This is very helpful if you
change the batteries and the watch gets reset to meters.
Also note, when you pull out the two batteries, you may not get the
watch to come up. This is because of a race condition when the watch
gets power. To fix this, look for the AC mark on the inside of the
watch. Under this marking, in a little space to the left, are two
copper pads. Short this out with a small screw driver to get the watch
to ground zero.
To fix the Metric measurements:
1. Go to the home screen on the watch. This is when the the 3 letter
abbr for the day is at the top. Also, if you cycle the mode button, it
is the screen where the final beep is "high."
2. Then press the "memory" button, which will take the home display to
the data screen. This shows current time, pressure and temperature.
3. Hold down the adjust button, until the set screen comes up.
4. Tab the mode/select button on the watch until you get a flashing C. Then press the memory button to toggle to F.
You can adjust all the measurements from this screen.
