When i am want to updates my device it want a new sever profile setting and when i clik the sever profiles it show me no sever profiles and it get a new sever profiles and no-1sever name, 2-sever id, 3-sever password, 4-access point, 5-port, 6-username, 7-password,now please tell me how do i set this setting
SOURCE: internet setting
do contact to your network service company. they will send u an internet profile settings which will install automatically to your phone.
good day
SOURCE: my picture messages cannot be
Make sure your subscription covers the desired service(s), and that the selected carrier (e.g. GPRS/EDGE) is available in the area. If you still have problems sending or receiving MMS (picture messages) or accessing the mobile Internet/WAP on your phone, you probably need new settings installed. Go to your mobile carrier website and follow the instructions to receive the settings in an SMS message. You can also contact your operator for the correct settings.
SOURCE: p990i touch screen problem
I encountered the same problem but was able to fix it. Just don't know if it's just temporary. Go to tools, control panel, other, set up wizard, tap yes, tap the second button before cancel, keep on clicking to the right direction until the numbers 1, 2, 3 and 4 appears. Tap the center of each number until blinking stops, save settings. For the first few steps you may use the jog dial found on the left side of the phone if the touch screen does not follow your tappings.
SOURCE: Purchased unlocked Sony Ericsson K800i can't use MMS
contact www.fixphonenow.com at 516-378-3711. ask to speak to Mark. he should be able to send you programming over-the-air to your phone. the phone needs to be configured to t-mobile. they are a t-mobile dealer and repair shop ill do it for you for no charge.
it will be setup for picture messaging, mms, web browsing, and t-zones
call monday thru friday 12-6pm if im not in leave a message and the phone # of the phone you need to setup.
thanks
Mark
SOURCE: G700 sony ericson - USB connection problem
hi ths is dacs
Try to format your memory card... that is the result of not safly removng ur phone from ur pc.. it usualy afects the memory card...
format the card using ur phone..ok...
