The paper roller drops down to capture the paper while I use the copy function from the printer. The paper will roll out and functions fine. However when I print to print a document from the PC, the paper roller doesn't drop down and no paper was being captured. The printer will show an error message - no paper in the printer.
SOURCE: hp 7410 document feeder
This possibly need you to strip off the cover. Check out www.fixyourownprinter,com and post th 'Q' there
SOURCE: hp 1400 does not print from print command by computer
sir reinstall your printer software and drivers or follow my commands go in your start>printers and faxes>and right click on your printer>properties>ports and select your port and apply
SOURCE: my HP laserJet 2200DN doesnt feed paper when printing.
it could be hardwre problem.. you need printer technician to replace some broken parts
SOURCE: My Mac can see the HP C4480 in the profiler but I
just right click on printer and remove thge offline and also chek the usb port and chage the cable also.
