Heater suddenly won't come on at all. No lights on control panel or anything. If bumped or hit on side then control panel lights and beeps for fraction of second as if there is loose wire. Cannot remove innards from wood case since its wired to control panel which is glued to front of case.
SOURCE: Quit working
Based on the limited info.I have, it sounds like the heating element is not getting power. suggest visually inspecting the switch and thermostat for burnt wires. Also check the heating element for broken electrode.
SOURCE: comfort zone infrared heater
Hello all , just push and hold the two buttons on the right for 3 seconds and it will reset. Joe
SOURCE: change temperature from Celsius to Fahrenheit on a comfort zone h
To change your heater display from Celsius to Fahrenheit: press and hold the "down" button and the "enter" buttons simultaneously for 5 seconds and release. - VS
SOURCE: I need a Pcb for comfort zone heater
Those control boards can be repaired contact me at [email protected]
Comfort Zone heaters do not have a display board, they
only had thermostat knobs.
Is it possible that you have a different model of heater?
Regarding suggestion to press two buttons on right to reset - there is no power. Will not reset. Regarding comment about burnt wires - I opened unit and nothing is burned of visibly broken but agree symptom sounds like loose wire because unit flickers on for an instant if hit on side
Follow power wire it goes to a block with little button in middle push button
