SOURCE: Hitachi CP-X250 LCD Projector
clean filter and reset the filter timer by advanced options filter timer and hold reset till menu shows then arrow up and it will zero out.
SOURCE: My Hitachi cp x250 projector powers on and
Most likely you have a defective lamp or it is near the end of its life. It's also possible that the high voltage power supply is going out. You might check the lamp hours - you can find this in the advanced menu. Also check the air filter, if you haven't cleaned it, the airflow might be restricted, shutting down the projector.
