The page prints but the lowest part of the words are not printing. It looks like an invisible line cuts them off. I don't know how to correct this! Any ideas?
Is this happening with every program you use to print? If it's just a single program, try changing the line spacing. It sounds as if you've got the line spacing too small for the current font and it's cutting off the bottoms in order to print the next line.
I had been experiencing this problem intermittently for some time, so I finally got a hold of HP support and with the second support technician, I did get a solution that worked for the document I was printing at the time. When Printing, click Printing Preferences, click the Advanced tab, under the Printer Features section, set Minimize margins to On. Per the technician, 'The printable area of the product increases (bottom margin 12 mm to 3 mm), so
that printing closer to the edge of the paper.'
Also, he recommended using the printer's Print Preview option under same the Printer Preferences window. When I did, I did in fact see the document's bottom paper being 'cutoff' with the old settings (i.e., Minimize margins Off), with it On, it look okay.
Hope this helps. Let me know if this works for you.
Does the bottom border show up in Print Preview? Some printers will not print the full page, to include the border if it is too close to the papers edge. If you adjust the border to be further away from the pages edge, it should print. Instead of applying a page border, you may have to draw a border using a rectangle shape and apply the desired line style. You can also try to adjust the border margin to measure from "edge of page" instead of measure from "text". This setting is on the options button located on the page border tab under the Borders and Shading window. This may allow you to adjust the margin enough to be able to print the border.
Using the print or printer setup (I can remember what is actually written) from within word. ensure that the print margins are not to small and cutting off your words, or if the print is appearing close to the edge of the paper when you print, you maybe outside the range of the prints ability to print that close to the edge of the page in whice case you would increase your margins in the print setup (ie from .125 to .375 or .50)
You may need to adjust your margins so that the bottom border shows. In other words, go to file> page layout>margins and adjust the bottom margin to a lower number, the check print preview.
If that does not work, try checking the border settings. Perhaps line weight has been set to 0 or color has been set to white or no color for the bottom, causing it to be invisible.
Make sure when you are printing that you go to propertys, graphics, and make sure color is selected, other than that, i woudld say contact samsung. good luck
