Not working
1) Look at your laptop computer to see if
you have an HDMI cable port. This port is roughly half an inch wide and
provides both the HD audio and video signal. If you don't, you are going to use
a DVI port on the laptop. This is the same port you use to connect monitors to
your computer.
2) Plug the DVI-to-HDMI adapter into the DVI port on the laptop with the
Blu-ray player. If you have an HDMI port on your laptop, you can skip this
step.
3) Connect an HDMI cable to the HDMI end of the adapter. If you have an
HDMI port, plug the cable directly into the HDMI port.
4) Plug the other end of the HDMI cable into the HDMI port on the HD
television. Power on your television, press the "Input" button and
select "HDMI." You can now see the contents from your Blu-ray player
on the TV.
Thanks for rating
Good luck
