Machine died mid cycle. door latch is stuck and there is wet laundry inside.
Hello Nina DeLuca - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. If the door does not open, then it sounds like the washer is possibly experiencing a communication problem with the control board, wiring failure or faulty door lock. Contact a professional to move forward accurately to properly diagnose/repair unit.
SOURCE: My Electrolux ewf1090 front loader door wont open
Turn the power off and leave for 5-10 minutes then turn on. This should release the door lock the problem could be the pump drain filter is blocked clean this and it should resolve future problems.
SOURCE: I have an Electrolux EW 548 F Washing machine.
It sounds as if something has got stuck in the filter jamming the drain pump,try draining the water out either through the filter but beware of the amount of water.Or take the drain pipe at rear and try to drain iinto a container or through the nearest door to an outside drain.Once the water is out you should be able to open the door.Then you will have to find out if some object is stuck in the filter(located at bottom right hand side).
SOURCE: The washing machine Electrolux 1087
Hi, if the washing machine stops in the middle of a wash cycle, the first step that should be taken is to perform troubleshooting steps to determine the cause of the problem. After the source of the trouble has been established, it can be resolved in most cases by continuing the troubleshooting process.
If after doing all these and the problem still persist, you have to call in a tech to check it out because there is no way to reset the Electrolux 1087
SOURCE: electrolux ewf 1090, have an electrolux ewf1090
ewf1090 washing machine not working?
error E50 is displayed?
but no reference in manual that helps.
Thank you, Chris. I resolved this by doing something similar -- unplugging the machine for about 30 minutes and then plugging it in and turning the knob. Spraked to life long enough to allow me to open the door.
