Coffee machine has just ceased to have power, I changed the fuse and still no power, can anyone help??
SOURCE: gaggia syncrony compact leaking water where
If you remove the tank, does it leak? If yes then check the spring loaded valve under the tank, also check the O-ring for damage.
SOURCE: GAGGIA syncrony compact coffee grinder motor is
Remove the brew unit and to the left of that is the the discharge area for the grinder, make sure that hole is clear, then adjust grind 1 number coarser, and check machine.
