RCA 24V511T 24" TV Logo
Posted on Jan 18, 2009
I HAVE A 2004 RCA MODEL 24V511T. dO i NEED A DIGITAL TUNER IN ORDER TO FOR IT TO WORK AFTER FEBRUARY 17?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 31, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
203
Points
Model has one NTSC RF and two NTSC composite inputs. It's compatible with analog Over The Air and non-scrambled analog cable broadcasts. After the US analog cutoff (currently scheduled for June 12) it WILL require a digital to analog converter to receive ATSC digital TV transmisions.
1helpful
Is the Magnavox TFT LCD 17 MF200v/17 have a digital or analog tuner?
I believe it has an analog tuner (NTSC) only. The original remote is pictured here: http://www.replacementremotes.com/philips/buy-313923807911-remote-control.html . The TV is listed as having been available in 2004 from Amazon.com. The manufacturer didn't have to include a digital tuner until 2005 for 36"+ models. For a 17" TV, they didn't have to have a tuner until 2007.
I hope this helps.
(You'll need to have a set-top box (digital-to-analog converter) to watch over-the-air signals.)
1helpful
How do I configure for antenna (on-air) reception?
TV has to have an ATSC tuner. Should find it in onscreen menu. Otherwise, you will need a converter box. About $50 at big box stores.
2004 MODEL 24V511T. DO I NEED DIGITAL TUNER IN ORDER TO RECIEVE
If you receive your TV signal ovr the air using rabbit ears or a rooftop antenna, yes you will ned a converted box. If you have cable or a satelite signal, no converter is needed.
Dan
I have a sony trinitron wega tv model number KV-32FS120 and I was wondering if it is digital ready or do I need to get a converter box
This television receiver has only an analog broadcast tuner and will require a converter box after February 17, 2009, to receive over-the-air broadcasts with an antenna because of the U.S.'s transition to digital broadcasting. Analog-only TVs should continue to work as before with cable and satellite TV services, gaming consoles, VCRs, DVD players, and similar products.
1helpful
Programming a ATSC DTV tuner on a RCA Universal Remote
Try a code for a "satellite receiver" of the same manufacturer of your DTV tuner. I've heard of a cross-remote complaint with the DirectTV box and the DTVPal box. Note, your DTV tuner may say RCA, but it could be manufactured by a common DTV tuner maker. The system looks very close to a Zinwell. Don't have an RCA model to try the codes out, though.
1helpful
Does my tv have a digital tuner (RCA Model E13320, 2/2001)?
The digital tuner has nothing to do with the new signal you will be receiving in February of next year. The new video signal is a digital signal. The old video signal is analog. Your television receives the analog signal and converts it to what you see on television. You need a converter box to convert the new digital signal back to an analog signal your television can convert.
Jerry
3helpful
2answers
External Tuner Device for VCR/DVD player
Just pick up an old used VCR that has a tuner built in. Only the very new ones don't have them (due to the DTV switch coming up in February).
1helpful
TV Repair Assistance needed
FLP stands for -- Front Lock Panel - I found it in a friends RCA TV manual. It is a lock you can place on the tv front panel buttons. When this is locked you can only use the remote. So once I knew that I went to RCA Service Center and ordered a new remote.. problem solved. So since your person couldn't even understand my problem, let alone solve it. I would like a refund please.
Thank you
4helpful
Is my tv digital compatible or not
https://www.dtv2009.gov/FAQ.aspx What you need to know is whether your TV set has something called a “digital tuner” already built in. If it does, your TV set will work after February 17, 2009. The best way to determine whether your TV set has a digital tuner built in is to consult your owner’s manual. If that’s not possible, you may be able to look up information about your TV set on the manufacturer’s website. Or, you can take an up-close look at your TV set. In any case, you’re trying to find out if your set has an input connection labeled “digital input” or “ATSC” (for Advanced Television Systems Committee, which is the DTV format).
Here are some general guidelines that may help:
TV set made before 1998 was a traditional “analog” set. If you bought a big-screen, projection TV between 1998 and 2004, it may have a built-in digital tuner inside. But chances aren’t great. Only a limited percentage of projection TV sets (and generally only those 42 inches in diameter or larger) included digital tuners before 2004.
If you purchased a new TV set since 2004, your chances of having a built-in digital tuner improve dramatically. Starting in 2004, many of the TV sets sold at popular electronics stores feature digital tuners that will work after February 17, 2009. But it’s not a sure thing. Even some of the newer TV sets are purely display monitors that lack the internal circuitry needed to pick up digital broadcasts. Usually these sets have been advertised as “HD-ready” or “HDTV monitor” sets. That means they can display digital and high-definition signals, but they need help getting those signals in the first place. You’ll still need a special converter or a cable TV connection. Hope this info above helps. Also, check your manual, and if you don't have it some manufacturers, (Philips does for some models) offer the manual on their websites.
2answers
2006 RCA TV Digetal Receiver
NBC newsperson said I should check nbc.com to learn
what to do for the change in February. Where is it ??
You want my solution ? Improve your web site.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
