Question about KitchenAid Dishwashers
How do you reset a KitchenAid dishwasher model: KUDE70FXSS4?
The Clean light blinks 4 times and this continues. I have reset the power with no luck.
    New Friend:
  • 12 Answers
Proper reset sequence for this model is to push any three buttons on the panel, one after the other, three times in succession, as in heavy duty-normal-light/china-heavy duty-normal-light/china-heavy duty-normal-light/china. All lights on the panel should then illuminate
Posted on Feb 19, 2016
  • Nick Salerno
    Nick Salerno Jun 18, 2016
    All the lights are illuminated. What are the next steps?
  • Murielle Dumas
    Murielle Dumas Feb 23, 2019
    Thank you! Thank you! Thank you!
    with my kitchenaid kdte234, I pushed the three buttons of Options in sequence. All lights on!
  • KitchenAid Master
  • 3,247 Answers
Press High Temp Scrub and Dry Heat option buttons in quick succession one after the other for about 6 sec until all the lights come on. Then press Cancel button. This should reset the dishwasher. Press equivalent buttons on the panel if the actual ones above are not there.
Make sure the dishwasher detergent dispenser lid is shut and the dishwasher door is shut before you start the above reset sequence.
Posted on Jan 02, 2013
  • 4 more comments
  • Dean Daghita Jan 02, 2013
    I am not able to close the door and push the buttons. Here are the buttons that are on the top of the door: Pro Wash, Heavy Duty, Normal Wash, Light/China, 1 Hour Wash, Rinsh Only, Pro Scrub, Hi-Temp Wash, Sani Rinse, Top Rack Only, Pro Dry, 4 Hour delay, Start/Resume and Cancel/Drain.
  • Sam Jan 02, 2013
    please clarify the reason if any for not being able to close the door. The buttons to press for the reset in your case would be Hi-Temp Wash and Pro Dry. Maybe you can try to run the reset sequence as explained in my old post with the door open and see if it works. When all the lights light up on the panel press cancel.
    I tried the high temp scrub and pro dry without success. The touch buttons are on the inside top of the door and when you close the door, you can't get to the touch buttons.
    I got the dishwasher pulled slightly out so I can close the door and touch the two buttons you mentioned. This did not reset the machine.
  • Sam Jan 03, 2013
    The sequence is High Temp/ Dry/ High Temp/ Dry for about 6-8 sec. If you are unable to reset the dishwasher, and looking at the fault light you mention, the heater unit is failing and will need to be attended to by a repair technician.
  • Nik Yelpir Mar 30, 2019
    How do you reset a K'Aid KUDS03CTBL3?
3 Suggested Answers
SOURCE:
  • 188 Answers
SOURCE: Kenmore dishwasher, model 665.170 344 01. "Clean" light keeps flashing and will not stop. Have tried everything in the manual and the light still will not stop flashing.
If the clean light flashes 7 times, pauses then repeats...
If the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive).
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on Feb 20, 2009
  • 25 Answers
SOURCE: KItchen Aid Dishwasher KUDI01FL Stopped Running and Will not Start
try the reset button sequence i posted in the other question..
Posted on Jan 24, 2009
Lights flashing 7 times
Never heard of 7 flasjhes.
Five flashes = No Print Head Installed. Install or re-install.
Eight flashes = Waste ink absorber* almost full. The printer has a built-in waste ink absorber to hold the ink consumed during Print
Head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the R R ESUME/CANCEL button to clear the error so printing can continue for a while.
A longer term RESET IS possible BUT without changing the blotters, you're exposed to ink eventually running out of the printer without warning but... if you still want to continue, here are the reset instructions. Good luck!
1) With the printer powered off, hold down the resume button and press the power button.
2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power button. The indicator will blink in green and remain lit in green.
Now press the resume button 4 times and then the power button. You've just reset the waste ink counter. Good luck. Just hope it doesn't come back to bite you!
Aug 31, 2014 | Canon PIXMA iP2000 Photo Printer
Password1752809
If you forgot your password and/or want to reset the router back to the default settings:
Step 1 Power the unit off by unplugging its power adapter.
Step 2 Insert a paper clip in to the reset pinhole. Press and hold the reset button with light pressure.
Step 3 Power the device back on by plugging it in. Continue to hold the reset button.
Step 4 Watch the lights on the front of the gateway. The M1 & M2 should come on solid. When the M1 & M2 begin to blink slowly, release the reset button.
The unit will reboot itself and should be at factory defaults. If the M1 light is not blinking about once per second, recycle the power on the gateway.
If the M1 & M2 continue to blink rapidly, you held the reset button for too long. Power the device off and repeat the reset procedure.
The default username for our routers is admin. The password is blank. If your router asks only for a password, use admin (lower-case). The default IP address is 192.168.0.1.
BEST OF LUCK
Dec 15, 2013 | D-Link DI-704P Router
My sony trinitron won't come on. I have a blinking light, it blinks 4 times fast. can you help me
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jul 17, 2011 | Sony Televison & Video
No picture, no sound. Stand bye 4 red light blinks
Jul 17, 2011 | Sony KP-53S70 53" Rear Projection...
Reset led blink 10 times
Jul 16, 2011 | Sony KP-57WS520 57" Rear Projection...
My standby light is red and blinking 6 times then quits, then blinks 6 times again then quits every time i try to turn on my tv
Apr 06, 2011 | Sony Grand WEGA KDF-60XS955 60" Rear...
The green light which goes off at the end of the cycle is continually flashing and there is a continual beep.
You may just need to reset your control board. Go to the link and it will explain how to reset the control board as well as explain what might cause the issue and how to fix it.
http://www.appliancerepairlesson.com/dishwasher-2/dishwasher-clean-light-blinking-7-times/
Good Luck
Mar 06, 2011 | Whirlpool DU930 Built-in Dishwasher
Sony 3 lcd rear projection tv hd w/ wega gate. kdf-e42a10. tv will atempt to turn, shuts down, greem power light blinks 12 times on average. red standby light blinks 4 times. i replaced lamp [ xl 2400...
Mar 02, 2011 | Sony KDF-E42A10 42 in. LCD Television
My standby light blinks 4 times repeatly and won't turn on
Jan 22, 2011 | Sony FD Trinitron WEGA KV-32FS320 32" TV
How to reset absober full mp198
PLEASE TRY THIS, Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter
Feb 26, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Dishwashers Logo
14,224 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
