Keurig Ultra In Home Single Cup Brewer with 54 KCups Logo
tgaetano Posted on Jan 01, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wont power up
Was working fine went to make coffe has no power and is plugged in recepticle has power
Dave Glabb
Level 3:
Master:
  • Master 257 Answers
  • Posted on Nov 25, 2013
Dave Glabb
Master
Level 3:
Master:
Answers
257
Questions
Helped
169390
Points
1085
Contact Keurig (866-901-BREW) for help
Wont turn on at all
If there is no power at all to the machine check the plug-in recepticle. Plug a lamp in it's place to verify it's working. If not check the house circuit breaker. If it's tripped reset it.
Unfortunately i'll have to know more about the machine to tell you more than that.
Coffe maker has shut off no power
Pad and Circuit board shorted. Return for replacement.
5helpful
3answers
My electric digital smoker wont heat. The timer works fine and the temp sets fine, but the element will not heat up . LAst use was the same problem then it eventually came on after some jostling of the...
Hi tee1134400...
Check all your connections going to the heating element...sometimes they will get corrosion on them and cause them not to function properly.
Please take time to rate me
1helpful
1 year old dryer has no power. Yes, it's plugged in, breaker seems fine. any ideas?
First you need to actually test for power, Breaker seems fine doesn't mean you are getting power to the recepticle.Please post back after testing for power.
3helpful
How do you convert the (2) 240 volt outlets to one twist lock connector on a coleman powermate maxa 5000 er genset
Make an Umbilical recepticle adapter. Buy the recepticle install the recepticle in a 4" electrical BOX on a plate with two manufactured 3 prong power cords plugging into the 2 outlets and terminating at the new Box twist lock recepticle you made.
TV WONT TURN ON AFTER POWER FAILURE
What type of TV to you have? Check manufactures website for possible solutions.
Search model # on: www.google.com
1helpful
Acer Aspire 3003 Power plug not making contact
You've probably damaged the dc power jack by trying to get contact. Local repair shop should be able to repair it for $100 and below. I wouldn't recommend going diy unless you're good with stuff like this.
Briel Sintrac cofee/express machine
I all ways have a good coffe(express)until now.Sems to me to much water and the coffe is no good
What can i do?
Battery charging recepticle
Here is a link to the IBM manual - warning what you want to do is probably a complete teardown of the machine and soldering equipment.
You may want to buy the power jack before taking it apart.
Try www.laptopjacks.com they have the right one.
http://www-307.ibm.com/pc/support/site.wss/MIGR-39796.html
Top Keurig Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
