Hi, I own a Tyros 1 which gave me a lot of pleasure the past almost ten years. I installed a hard drive about a year ago and loaded a large number of extra arrangements. A problem developed recently. At first I found that the hard drive was not "seen" or not accesseable. More recently a more serious problem appeared in that when I switch the keyboard on, the starting motions are not completed and all buttons on the keyboard are non-responsive, neither is there any sound. With all the buttons being non-responsive it also means that I cannot access utilities to restore the keyboard to factory settings and have the problem resolved that way. Does anybody have an idea what the problem could be? I will really appreciate if anybody could come up with any idea what should be done to resolve the problem. Thanks you. Dolf
  • 4,806 Answers
Hi.
Try holding down the rightmost white key while powering up the keyboard. This is a minor system restoration, which may solve your problem.
Below is a way to run diagnostics as well >>>>
DIAGNOSTIC TEST:
if you think there might be something wrong with your board, you can have it perform several tests to see if all works well.
1. Power off
2. press C2# - F2 - G2# (all three together) and while keeping them depressed,
3. switch the power on.
You'll see the word "TEST" on the display
With Tempo - / + you can go to the test you want to perform. Start/Stop will start the test. Wait till a test is done!
You can check following items :
001 : Version
002 : Rom Check 1
003 : Ram Check 1
004 : flash Check 1
005 : Wave rom Check 1
006 : Effect ram Check
007 : TG 1 Check
014 : Pitch Check
015 : Output R Check
016 : Output L Check
019 : EQ low Check
020 : EQ mid Check
021 : EQ high Check
023 : Mute Check
025 : MIC Test (PSR3000)
027 : Sw, Led Check
028 : All panel led on Check
029 : Red led On Check
030 : green led On Check
033 : All LCD on Check
034 : All LCD off Check
036 : LCD Brightness Check
037 : LCD Pattern Check
040 : Pitbend wheel Check
041 : Moduration wheel Check
046 : Padal 1 Check
047 : Padal 2 Check
053 : Midi Check
055 : Video out NTSC RGB (PSR3000)
056 : Video out PAL RGB (PSR3000)
057 : USB To Device / Host Check
058 : USB Storage Device Check
059 : Card Check
061 : Keyboard Type Check
067 : Rom Check 2
068 : Ram Check 2
069 : flash Check 2
070 : Wave rom Check 2
071 : Effect ram Check 2
088 : Factory set
089 : Test End
When at 086, press Start/Stop to exit the test mode and your keyboard will continue to start up normally.
Good luck and regards.
Posted on Jan 01, 2013
6ya staff
SOURCE:
Anonymous
  • 14 Answers
SOURCE: restore factory settings without CD
Hello
Reboot your system . Press F11 when started . Generally F11 is for recovery to the factory settings . If there is any other option for recovery , select it . Your system will be booted to the factory image if tha is already stored on your system.
Jas
Posted on Apr 13, 2009
Nevin Cumpston
  • 7 Answers
SOURCE: how to reseat the hard disk drive
If the HD has never been removed it is unlikely it needs reseated. You need to go into the BIOS (press F1 during start-up) and see if the HD is visable under the drives section. If it is not then it is dead and needs replaced. Data recovery may be necessary if you need anything from it.
However to reseat it, turn the laptop over and there are two screws that come out to slide the HD out from the side. Pull it out and then push it back in firmly and replace the screws.
http://support.dell.com/support/edocs/systems/latd630/en/SM_EN/index.htm
Posted on Jun 07, 2009
Eighty_Three
  • 6 Answers
SOURCE: Dell XPS M1330 - Backlight not working
If you are having issues with a backlight I would check the lcd inverter first. It is usually 20 dollars on ebay. I would avoid contacting dell as they are no help to people that are out of warranty.
Posted on Aug 09, 2009
sijudoniston
Siju Doniston
  • 134 Answers
SOURCE: ibm restore to factory setting
The below link will solve your problem
http://www.intrepid.com.au/how-to-change-your-windows-xp-product-key-without-reinstalling/
Posted on Aug 27, 2009
parrotheadpc
Chip
  • 2600 Answers
SOURCE: HP Pavillion DV8000 Factory Restore
HP.Support.drivers put your model number in the search box, choose drivers - software. All the files that are compatible with your computer are there for the downloading and all is free.
Posted on Sep 09, 2009
Moderate scraping noise coming from my right front tire
a shimmy condition indicates it needs a wheel alignment
best take it to an accredited front end specialist shop for a proper diagnosis of the problem
Jun 22, 2017 | Cars & Trucks
What are the words to the gospel song "Ten Thousand Years"?
Hello, Verse 1, Soon I'll come to the end of my journey. And I'll meet the One who gave His life for me. And I will thank him for the love that He gave me. And ten thousand years or more I'll reign with Him. Verse 2, We will just begin to sing loves sweet story. And it's a song that the angels they just could not sing. And I've been redeemed by the blood of my Savior. And ten thousand years or more I'll praise His name. Chorus 1, Ten thousand years...we'll just be started. Ten thousand years...we've just begun. The battle will be over...and the victory is won. Ten thousand years...and we've just begun. Chorus 2, Ten thousand years...we'll just be started. Ten thousand years... we've just begun. The battle will be over...and the victory is won. Ten thousand years... and we've just begun. For the battle is over & the victory's been won...Ten thousand years and we've just begun. Ten thousand years...and we've just begun.
Aug 15, 2014 | New Haven Records Southern Gospels Top 20:...
I bought this DELL D600 about 3 years ago for my fiancee, now my wife of 1 year, and have had a lot of problems with it
it is HIGHLY doubtful that your internet speed is faster than 54Mbps, and would be little difference in performance.....
Especially given that most webmasters throttle their websites to around 3Mbps. If the website your're trying to load is only sending it @ 3Mbps, then both cards should load it similarly.
Your difference is FAR more likely in the DRIVER(s) being used, (or attempted, but not properly removed.)
Tallon41
Sep 07, 2012 | Dell Latitude D600 Notebook
No light- not detected by computer-humming sound
Hi Mary
It sound like you have a dieing hard drive . If you unplug it and leave it for 2 minutes then plug it back in to see if a 'cold start' will help it. If you do get it running get all the pictures/files/documents of it as soon as possible. And don't use it again.
Seagate have a program for testing there hard drives at
http://www.seagate.com/www/en-us/support/downloads/seatools
download and install it and see if it can help.
If it still wont run and you have photographs/files/documents that you need of the drive you will have to look at data recovery.
I fix a lot of computers and over the past 2 years I've come across 4 Seagate drives that have failed and only one other brand .I don't know whats happening with the company because years ago they were the best hard drives you could get but now from personal experience I would give Seagate hard drives a wide berth.
Hope this helps
Alistair
Jan 11, 2011 | Seagate FreeAgent Pro 1TB External USB...
1989 gmc sierra 6.2 liter diesel hard start when hot
hi, i have seen this problem ten years ago twice, but i was dumbfounded by the answer. all details aside, I replaced the ecm, and never had the problem again with both of them. this repair was a recommended repair by the local truck depot in my town, they stated the ecm got hot along with the truck and it lost the injector sensor signal. now, don't take this solution and run with it, i haven't repaired a 6.2 diesel in ten years and i maybe off track completely. but at least maybe you could ask around your town or maybe a large truck facility about this. of course, you should take to a shop to have diagnosed. hope i could help.
Jun 07, 2010 | 1989 GMC Sierra
Blank Computer Shuts Down For No Reason
the old hard disk died a month ago and you got a new new one now rt? that means you were not using your computer for one month.So there is a chance of processor heat sink paste worned out and processor is getting hot. So you need to remove the heat sink and apply new heat sink paste and re-fix processor, re-fix ram sticks also.. make sure processor fan is working well.
if its still having problem, you need to check the SMPS...
Another reason, you need check to the compatibility of mother board with hard disk. That means, you need to check how much size of hard disk your motherboard will support?
Apr 02, 2010 | Western Digital MY BOOK HOME 1TB EXT...
Hear disk spinning in hard drive but my mac won't recognize the drive
This is probaly file errors on the disk that have generated over time. The problem is that your mac software wont load up the drive unless it is formatted or accessed in DOS. There are some freeware programes which you can download which recover hard drive from DOS (spinrite etc). If you cant access this in DOS with the software then the hard drive is trash.
The main problem of all this is that this is almost symptoms of a hard drive faliure or future faliure. If you get the info off your drive back it up defrag and format the drive every year.
Bear in mind Hard drives only have a lifespan of 1-3 years. In addition try not to fill them over 60% as your drive will last a lot longer.
hope you can rescue your drive.
Jul 28, 2009 | LaCie Big Disk Extreme with Triple...
Just fitted new hard drive to my philips ls1200 but cannot get the recovery software to load past the licence agreement page. the machine locks up at this point. any ideas please
hi it might lock up due to you have change a part years ago they used to tattoo equipment so that it could not be used in other machine hope to stop theft.
but this if you change more the 2 item try doing it with the old drive in it
Nov 26, 2008 | Computers & Internet
Washer stopped dead in the middle of cycle
CHECK ALSO the sensor switch underneath where the door close , you gonna need a tester for this task ,hope this helps AJ
May 05, 2008 | Hotpoint WMA13 Front Load Washer
Tv picture quality
You have a defective light engine. We just went through this and we have the same TV that you have. Hitachi knows about the problem but will play dumb when you first call. If you deal directly with their Customer Relations Department 800-654-7013, it will make a lot of difference than regular customer service.
Here's how they handled our situation. We called Hitachi after lots of research online and they gave us the names of some certified dealers in our area. The tech came out and in less than 1 minute said the TV had a defective light engine. We called Hitachi back and low and behold, they are aware of the problem...imagine that. Hitachi called the dealer directly and once the dealer confirmed the problem, they agreed to send a brand new light engine out to the dealer and the tech came out and replaced it. Here's the kicker...Hitachi will pay the for the part ($1500) but they ask you to pay for the install. Our install was $400. This was worth it to us being that we spent $3600 on this set 3 years ago. Once the light engine was replaced, the TV looked BRAND NEW! Please deal with their customer relations department at the number I lised above. If you deal with customer service, they will have you chasing your tail...so to speak! Good Luck! If you're willing to cover the install, the rest should go pretty smoothly..at least it did for us:)
Nov 19, 2007 | Hitachi 60V500 60" Rear Projection...
Open Questions:
SBCglobal MAil Tollfree ??{1=+855=+{536}?{5666}#O@ PHoNe NuMbER NEW JERSEY call or contact SbCgLoBaL mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL mAiL USA Calling SbCgLoBaL mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL mAiL USA's phone numbers against each other. Contacting SbCgLoBaL mAiL USA in General WhileI:855:,:5365666 is SbCgLoBaL mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I:855:,:5365666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL mAiL USA.
Nov 11, 2019 | Best Computers & Internet
SBCglobal MAil Toll{1*!855*!536!*+5666}#O@@# Free NuMbER HELPLINE call or contact SbCgLoBaL mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL mAiL USA Calling SbCgLoBaL mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL mAiL USA's phone numbers against each other. Contacting SbCgLoBaL mAiL USA in General WhileI:855:,:5365666 is SbCgLoBaL mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I:855:,:5365666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL mAiL USA.
SBCglobal MAil CuStOMeR {1.~855:.536**5666}#O@ Care SUPPORT NUMBER call or contact SbCgLoBaL mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL mAiL USA Calling SbCgLoBaL mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL mAiL USA's phone numbers against each other. Contacting SbCgLoBaL mAiL USA in General WhileI:855:,:5365666 is SbCgLoBaL mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I:855:,:5365666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL mAiL USA.
SBCglobal MAil TecH SuPPoRt {1^!855@^536^$5666}#O@ CUSTOMER SUPPORT call or contact SbCgLoBaL mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL mAiL USA Calling SbCgLoBaL mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL mAiL USA's phone numbers against each other. Contacting SbCgLoBaL mAiL USA in General WhileI:855:,:5365666 is SbCgLoBaL mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I:855:,:5365666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL mAiL USA.
Computers & Internet Logo
95 people viewed this question
Ekse
Marvin
Marvin
