I had this problem, our kenmore dw would leak maybe 1 out of 5 runs. found that the overfill float was so full of crud and calcium that it was weighing it down, and alowing too much water in - thus leaking out the top of the shaft of the float.
You must unlatch the float below the dw, very difficult, try a mirror, you also must remove the micro switch attached to the bottom of the float first. This fixed the problem!
No it isn't draining properly. You need to clean out the debris mesh at the bottom of the tub under the dryer bar this will usually fix this problem. Good luck.
