I got this tablet for christmas, my 3 year old put a password on it, and, no one knows what it is....Until i can get rid of it, I am locked out...can you PLEASE tell me how to get rid of that unknown password so i can use it. PLEASE, don't send me all over the net or charge me an arm and a leg for an answer.......Thank You
SOURCE: I bought a Archos 9
hi, you could try...archos9...maybe that is it?, that is device archos, and number 9..if not try the serial number or model number, there should be a label on it with this on, if not check out the paperwork see if the model number is there with that..good luck hope this helps
SOURCE: I have a coby kyros
go to other WI-FI hotspot and check if you have the same problem.... otherwise their maybe a problem on your tablet or wi-fi module.
SOURCE: my coby tablet won't open
Hi s112ronnie,
If your Coby tablet suddenly has no response or powers off, an elec-trostatic discharge may be the cause. In this circumstance, please follow these procedures for recovery:
1.Reset the player (use a paper clip to gently press the Reset button (on the bottom of the player).
2.Turn on the unit again
NOTE: Back up your data to an external source prior to performing reset.
Hope it helps.
Thank you for using FixYa.
SOURCE: will not take charge
Sounds like your battery is knackered, only thing to do is replace it, you can check the battery with a voltage meter or take it back to the supplier and ask them to check it foryou.
SOURCE: Is there a way to
Yes : boot from the recovery partition (you'll need to give the boot process some more time to keep the choice of the bboting partition displayed :
Windows+Pause, Advanced, 3rd "Parameters" button, change to 10 seconds.)
