SOURCE: problems setting up Belkin wireless G+ mimo modem router/usb network adapter
I keep losing connection to internet. I have comcast rca modem with belkin wireless g router. HELP???
SOURCE: Access Internet using wireless USB adapter
Apparently either you or someone else enabled encryption on your wireless router. This is in general a good thing, it keeps neighbors and people around your unit from accessing your network.
First are you sure the wireless is accessing your router -- there may be several routers named default or linksys in radio range?
Second you may be able to find the passphrase / key / password in the configuration of the wireless in the other computer.
Third if you can access the router config
Generally by typing something along the lines of
http://192.168.0.1 into a browser like Internet Explorer
then you need a userid and password (that defaults may be in the manual for the device)
Then navigating to wireless security or some equivalent name you should be able to find the WEP passphrase, key, password.
SOURCE: Suddenly lost internet connection on 2Wire DSL modem
hmmm...only thing that makes sense here is that your dSL is unhappy...did you check that phone line into the modem? that's what the internet light means when it's out, actually..if its not the line, then it's the modem..
not much else that is off on this.
check your computer warranty here 4 FREE
SOURCE: Intermitent DSL/Internet Connnectivity 2701 Router
Hii,
* If you can connect after disconnecting power and reconnecting, it means there is formation of static charge on modem
* Check whether there is any cordless phone or any other satellite devices next to the modem. If so, move the modem 10 feet away.
* If your modem is placed on carpet, please place it on wooden desk
For guest:
Do you see the power is also interrupted while loosing connection? If so try plugging the modem into different socket. Dont waste money for simple problems.
If this doesnt work, please dont rate me down, if it works, please rate me as fixya!!! lol...
Have a nice day!!!
SOURCE: Speedstream 4200 setup
To configure my siemens 4200 modem I enter 192.168.254.254 into the address bar of the internet browser. You should get a login screen that ask for your user name and password. Default user name should be admin and the password should be admin. I hope this helps you
