If your Lenovo desktop is pre-installed with Windows operational system, press one-key reset key when your laptop is power off. Or press Shift + B to come back to factory setting instantly when Lenovo desktop is open. Or press F2 when your Lenovo desktop is powering on. Few seconds later, a dialog pops up with several options, one-key reset and reset factory setting. Follow the operation wizard to reset factory setting is OK. Related topic:
Hi.
1.Turn of your computer
2.Restart your computer.
3. Repeatedly press the F11 key.
4. When you hear beeps or see a logo,release the F11 key.
5. If you set a rescue and recovery password, type your password when prompted.The r&r workspace will open after a short delay.
Select the option restore your system.
Regards.
SOURCE: HP A620N DESKTOP WINDOWS XP RESET TO FACTORY SETTINGS
Restart your computer now as soon as you hit the power button keep on holding Alt key & keep on tapping F10 key Alt+F10 it will open the recovery console select full factory restore and follow on screen instruction this may vary depending on your computer and operating system (Note:this will erase all datas on the computer) or you might try Restart your computer during the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart You will also need to set the time and date hope it helps
