Horn was on continuous, alarm would would not turn off. Removed connections to horns. Blown fuse replaced, reconnected horns, fuse blows again. any suggestions please.
I verify its not a stuck relay...
I disconnect connector under dash and horn stops...
I then suspect its the Horn contacts or a worn grounded wire in air bag/horn switch assembly in steering wheel.
The decorative Vinyl cover shrinks with age...presses on horn contacts against air bag.
I Disconnect Air bag connector (identified as Yellow wire and Connector) usually under dash.
WARNING: ( I Do not - I DO NoT probe the yellow harness/connector with a meter or test light. A test light WILL Detonate my air bag, and impale the bracket in a nearby object/person - me.)
I Removed screws (2) behind steering wheel - which allow air bag horn assembly to be removed.
I Disconnect Air bag connector in this location as well (identified as Yellow wire and Connector) and then;
The red (color varies) and black Horn wires will be plugged into ribbon connectors usually (2) two that feed/connect to contacts for horn function on face of air bag.
I pause here and verify horn will stop blowing when I disconnect the wires going to horn contacts. So I get horn blowing again...
Check horn: To verify this is the cause; I reconnect (whatever fuse/relay/ connector (Not the airbag connector) I disconnected so they will stop blowing) and get horn/s so they are blowing again...
Then I disconnect the ribbon connectors to verify blowing stops.
Note: The experience I had with horn on
Buick Park Ave was at night when temperature cools after hot day, the vinyl cover shrank and horn blows... pressing on horn area of steering wheel firmly would stop horn briefly - then continue.
Note: I will need a rivet tool and rivets... to reassemble.
WARNING: I Do not drill into airbag explosive container. If I do not know how to carefully drill off correct rivet heads and remove vinyl decorative cover from air bag/horn... I STOP and go to the junkyard or ebay and purchase/replace the airbag/horn assembly.
I continued by drilling out rivets (the rivets holding vinyl cover) by using a drill bit as large (or smaller) as the head of rivet and drill gently to release head from rivet body/shank.
I mark all pieces with a magic marker to verify I reassemble right side up (all metal brackets and trim plates and cover).
I Remove vinyl cover exposing horn contact pads which were sandwiched between cover and air bag container.
I used a razor blade to remove vinyl honeycomb material from area of vinyl cover - that when pressed - would activate horn/contacts.
Only a 1/16 of an inch or less needs to be removed.
(I Bend cover inside out and shave material off of area slowly. Care not to cut myself.)
I Reassemble in reverse order with rivets.
Check horn: ...function at this point... by plugging in horn connectors and assure horn contacts work properly as expected.
Hi Raygin, relay had blown, many thanks problem solved,
