Cuisinart11 cups (total processed weight varies by food) ... PowerPrep® metal dough blade, metal ... bowl at the top with ... filled out. WHEN. REMOVING BLADE: CAREFULLY REMOVE. THE METAL BLADE BY .... (If machine does not ... not put base in water or... These features, plus the .... have passed into the ... food from leaking.
Cuisinartmatching outline O on top of .... base in water or other liquid. General ... does not fit fully in the outlet, ... as you would sharp knives, out of ... 11. KNEADING YEAST DOUGH WITH DOUGH BLADE. 12. KNEADING BREAD DOUGH ... loodfrom leaking...... uid onto dough as it passes under ..... Fill the feed tube wilh the pieces,.
I would suggest looking around at thrift/junk stores like Goodwill and the Salvation Army. You might be able to find something that will fit in your appliance or something you could modify easily. In the meantime, you can contact Maxi-Matic through their website at http://www.maxi-matic.com/index.php. Click on "Contact Us" and let them know what you need. They may even send you a replacement part for free. Also, did you check the user manual that came with the appliance? You might find a source for replacement parts.
If it is model 5KPM5 then there is a pin through the shaft inside the planetary that engages the pinion gear. There is a circlip above the gear clipped to the shaft that holds the gear into engagement with the pin. I've not seen one drop the shaft out in my life, the circlip would need to pop off & the gear would need to jump up and then the pin would need to slide out. All the bits would be there inside the planetary waiting for you to discover them.
The power cord you need can be purchased by contacting the manufacturer at this site Website they have other retailers who can provide the part you just need to contact them first to know where and possibly how much.
I have several recipes for bread both yeast and none. But not enough space here.
French Bread.
Use C blade. 3c plain flour.2Tbs rapid rise yeast. 3 Tbs sugar. 2Tbs salt
1c water. 2/3 c of milk. 3Tbs margarine or oil. heat together until 130F/55C add to yeast mixture and stir in with C blade add in an egg and stir.Empty onto a floured counter. Knead by hand for 8-10 mins cover and let rest for 10 mins.
Divide dough into 2, shape into loaves place on greased cookie sheet cover and let rise 15-30mins. Bak in a 400F/200C oven 18-20 mins until light brown,Remove cool and enjoy.
Try "The Gourmet Depot" website or search "small appliance parts" and find a site that carries the Oster blender part. You will need the model # of the blender.
