Question about LG 42LC2D 42 in. LCD HDTV
BOUGHT SAMSUNG LE40A656 LCD CAN,T GET SKY REMOTE TO WORK
I have tried several codes to programme into my sky remote to operate my TV but to no avail. Even went back to Sky tech support whi say they may not have a code for this TV yet?
Has anyone got a code that works?
I tried the closest model no. in the Sky list in the system setup, I think the code was 0840. Cover the front of the remote and press TV, then press red & select button until the remote led light blinks twice, key in the code 0840 and then press select.  Try the volume button and this should work.  If you get stuck go into interactive and system setup and select setup of sky remote and it gives you a list of makes and models, this is the closed one to the LE40A656 and works with mine.
Hope this works for you.
Posted on Jan 28, 2009
    New Friend:
    Problem Solver:
  • 10 Answers
0060 and 1340 do not work with my model of Samsung (which is different to yours)
I found the code can vary according to the particular Sky Remote you have.
Look in the battery compartment for the version (it will say something like Rev 8R or Rev 9F)
For my model I found code 1647 worked with a Rev 9 remote but not with a Rev 8 remote
I found codes 1277, 1340 and 0646 worked with a Rev 8 remote but not with a Rev 9 remote
Other codes that worked with certain older models of remotes included 2079, 1177 and 0088
Posted on May 17, 2013
SOURCE:
What is the sky remote control for Samsung
Hi
Samsung
4 digits: 0060
3 digits: 065, 584, 037, 245, 476, 398, 516, 292, 318,037
Samsung (6000 series)
4 digits: 1340
As you used 0060 and it didnt respond please try to programma with the other 3 didgit codes.
If still you cannot programme it follow the below instruction:
1. To control your TV firstly switch on the TV set, point the Sky remote at the TV,
2. Press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice.
3. Continue with this process by continuously pressing "TV" then "Standby" then "TV" then "Standby" etc until the TV set switches off. This will start using the inbuilt codes to programme the remote.
Thanx
Jul 27, 2010 | Samsung Televison & Video
Just bought a 42 inch lg tv and cant programme my
please follow the steps below with you sky remote:
TV
RED + SELECT (hold these down until it flashes twice)
TV
0056
Try the volume button if this works then press SELECT. If it does not work then press TV again then try the volume ( repeat this step until the volume works. Dont forget to press the SELECT button to save the code to the remote.
This should sort you out. Please leave a thumbs up when you get it working.
Cheers Little Dish Fitter
Sep 24, 2009 | LG 42LC2D 42 in. LCD HDTV
Tv code
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0060 (samsung code)
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Aug 25, 2009 | Samsung T220HD 22 in. LCD TV
I need a code to allow me to operate sky from my samsung tv remote
the remote will only operate samsung products, you cannot program it to operate other manufacturers products, sorry.
May 08, 2009 | Televison & Video
Code to programme Sky Remote to operate new TV?
i have the same problem with the codes 0035 0125 0049 everything works except turning the volume up. have you found a solution yet???
Dec 31, 2008 | Televison & Video
Sky remote code
You will need to go to Sky's website and order a new remote if this doesn't work.
Press tv on the remote
press and hold Select and red until the remote LED blinks twice
type in 0 0 6 0
press power button on the remote, if the tv goes off press select and it should control all the tv functions.
if the tv does not go off press tv then power buttons on the remote and keep doing this until the tv goes off, then press select once the tv goes off.
Like I said earlier, if this doesn't work you will need to order a new/replacement remote via Sky's website then put the code listed above in.
Jul 18, 2008 | RCA RCR660 Remote Control
Code for Samsung remote control
With your Sky + remote.
TV
TV
0060
cheers
Little Dish Fitter
Dec 29, 2007 | Samsung TV Remote Control
SONIX tv remotve code for sky
I bought this sonix Lcd Television without remote.I bought a master remote but i dont know the code to use on the master remote.please
Sep 09, 2007 | RCA RCU1010RF LCD Touchscreen Remote...
LG 42LC2D 42 in. LCD HDTV Logo
891 people viewed this question
Ekse
