Just can't connect to wifi
Had same problem - said signal weak although strong on other devices, and hung on authenticating.
Cordless phone on base unit was beside wireless router. Moved unit and turned off phone. Problem disappeared, and signal showed strong.
My signal is strong and it still says authentication problem.
My monther's issue was because her ISP's (Bell) router, home hub 3000, comes default with the 2.4G and 5G SSID named the same with the same password. So her 2.4G was on a Band that was super weak, like 30%, but her 5G was at 90%. This was causing her wifi connections to use 5G as it was more available. Problem with the kindle is that it is limited to use the 1 - 11 channels / 2.4G only. I resolved this by going to the routers config (192.168.2.1) and changing the SSID from Bell553 to Foxtrot. Then i changed the 5G SSID to Foxtrox-5G and made different passwords for both. Rebooted the router and the kindle was able to connect to the 2.4G network.
Why my jxd dont wanna connect to my wifi
SOURCE: I have the Archos 101
I had the same problem with my third Archos 101 (I've had two replacements to the first one I bought in June 2011). I just got the third one two days ago and it wouldn't connect to my WiFi like the previous two would. I had to add the 101's MAC address to my router's setup and now I'm connecting to the Internet. Alternatively, if your cell phone supports tethering (my HTC Tilt does) you can tether your 101 to access the Internet through your phone. Mine is working well that way....for now.
