When i switch off for a few minutes ,then switch back on the blue light on the front of the tv flashes no picture .i then switch off for about 30 minutes and it works again
SOURCE: HITATCHI ULTRAVISION P50S601...POWER LIGHT BLINKING...WONT COME O
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also
ensure that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem with no receiver box
or dvd connected.
If that does not work, and you keep having a flashing
led on front of the TV, and tv turning off by itself after a while,
that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The
internal circuits are jammed because of electrostatic
charges accumulating on capacitors, or because of a wrong voltage read
by the main chip on your monitor controller board. this started the
protection circuit.
2 The protection circuit detected a wrong
voltage or abroken contact, identified an internal fault and kicked in
, startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults
that can occur are a blown capacitor on power board, a
convergence IC has blown, or a fault on Digital board.
Check also
the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you
can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
SOURCE: Hitachi Plasma TV model P50H401
I think you have problems with the digital main PWB.
If the power PWB failed, turn off and change the pilot ligth to red.
SOURCE: 55HT79 HITACHI BLUE POWER LIGHT BLINKS ON AND OFF.
I can't help you because after 26 months of ownership mine is doing the same thing (started on 7-12-09). Judging by the number of people with the same complaint I believe Hitachi knows that they have bad boards but refuses to replace them for customers unless they are within warranty. It also explains why the merchant that sold it to me in 2007 stopped offering Hitachi in 2008.
I'm disgusted because I'm anticipating a $300-$500 repair bill simply because Hitachi's design did not provide an external way of resetting it. Impossible to get to the menu to do a reset within 12 seconds before it starts the powering on booting cycle again.
Adding salt to the injury, mine is wall mounted and repair people will only work on it if it is readily accessilble when they walk in the door or if it is brought to the shop. Know what a 55" plasma TV weighs? Too much.
SOURCE: hi,i have an hitatchi p50t501
The Blue Blinking Light Hitachi.
When the light blinks 4 times it means you can possibly have 4 problems with your plasma.
1. X-Sus
2. Y-Sus
3. Power Supply
4. Sdr U or D
A good way to determine if you can fix this problem yourself is if you can build a PC. If you cant this can cost you upwards of 600$ to fix.
First get a flat area and lay a soft blanket down and lay your TV down so the back is up. Then goto your PC and goto Google and type "P50T501 Service Manual .PDF" you can buy it or if you look hard enough you can get it for free. Next in the service manual it will have a diagram of the Circuit Boards and their locations. Take the back off your Plasma and check the 4 boards. Look for burn marks, cracks, smoke mark. Take your time and look closely. When you find the broken boards unplug it and take the part number and find the replacement online. Plug it in and you should be good to go.
When i had 4 blinking lights i had to change my SDR U and D boards. They cost 100's a piece for Refurbished boards. Keep in mind im a contractor not a techno geek, and i was able to diagnose and fix my problem rather easy.
SOURCE: Hitachi P50H401 50in Plasma - No sound / No
first I would check firmware and upgrade if possible, then if no avail try hard reset and try again
