Question about Karcher Garden
I have karcher k4.98. I can not get the detergent to come out. I have checked the trouble shoot in the manual and all items are ok. Any ideas ?
    New Friend:
Just had the same problem, brand new machine, the detergent feed pipe was squashed under the bottle holder bracket!
Posted on Mar 08, 2013
5 Suggested Answers
SOURCE:
  • 420 Answers
SOURCE: Karcher G2600 VH - low water pressure
If the spill valve activates is "spills" water under the washer. There is a restriction or the pump has become inefficient and will not pump the volume and pressure it should at full RPM.
Posted on Jul 20, 2010
SOURCE: B302 - unable to start detergent flowing - How should it work?
It will only pick up detergent if you use a low pressure detergent nozzle - or no nozzle at all. It also takes a while for the detergent to get to the nozzle.
Posted on Nov 19, 2007
  • 92 Answers
SOURCE: karcher washer went dead
Dear jimbocom,
The problem is that the spill valve got stuck. When the machine is working and the gun is closed, a valve( spill valve) moves with the accumilated pressure and switches the machine off. So what happened is that when the spill valve did its job, it found no water...and remained stuck. This leaving the machine in an off position. Service and lubrication to the spill valve must be done or completely replacing with a new spill valve. In my opinion you have no serious damage, but this job must be carried out by an expirienced technician.
Regards,
MG.
Posted on Nov 05, 2008
  • 92 Answers
SOURCE: trouble with Karcher Pressure washer
Dear Pgarciax,
It is important that you must have mentioned the model number of your Karcher. Just the same I can surely say that your machine's fault lies in the "SPILL VALVE"
When the gun is open and pressure is being produced, the spill valve is in a relaxed position. Also it has at the bottom a valve, which when pressure is produced it is closed. If this does not close due to dirt or corrosion, the pessure goes down. Now when you close the gun,pressure forces the spill valve down to close the electrical system. Now if the "o" rings of the spill valve are damaged, the machine will start going on and off while in stand-by. So if you know how to locate the Spill Valve, all one has to do is change it with a new one.
In some Karcher machines there are 2 spill valves. One regulates pressure and the other one is for switching off the machine when the gun is closed.
Low pressure could also be due to faulty suction or delivery valves. Most probably the suction valves.
But when saying that there are short interruptions while in stand by, I stick to the fact that the spill valve needs renewing.
Regards,
MG.
Posted on Nov 19, 2008
I have a karcher K2.89. It works fine apart from the detergent reservoir - nothing seems to pass through and we' ve lost the manual. Can anyone please advise?
https://www.manualslib.com/manual/286316/Karcher-K-2-89-M.html
manualslib has a download option you have to tell it you are not a robot and may have a capta picture test.
click on a page of the manual and you will see the download button at the top of the page .
May 11, 2018 | Karcher Garden
My karcher isn't giving me hot water why? It's a hds 601c
Morning Chris Taylor,
You have an igniter/burner coil inside your system that has to be
functioning properly to have good combustion going inside the coils of your heater unit (very bottom).
I tried to pull the documents to see if yours was kerosene powered (like mine: not a Karcher)... but could NOT pull your HDS 601C up on the company site (Karcher.com, sorry... It's me & my new PC).
Poor water = de-lime water coil procedure
Cool water = No combustion, check kerosene, oil (burner fuel)... filter... (etc.) and check your spark!
If your air supply is insufficient to support great combustion your ignitor & fuel nozzles can get heavily built up in soot. My manual says to clean it with detergent & water... I have only ever used Berryman choke & throttle body cleaner.
All the precautions... don't hurt yourself!!
Hope this helps...
KARCHER HDS 601c ECO STEAM CLEANER BOILER HEATING COIL ELEMENT HEATER...
Operating manuals
http://www.ultimatewasher.com/download/hot-water-manual.pdf
May 01, 2016 | Karcher Garden
On my Karcher 2600, I filled the detergent tank but as I was washing the bus none of it was coming out, it was still full when I finished, any suggestions Ted?
I see this lots of times , the detergent tank will only mt in the low pressure mode of nozzle , this is the only way a siphion will develop inside the soap tank and then high pressure can be used later to wrinse the item off well using just water
Nov 06, 2015 | Karcher Garden
2600 PSI Pressure washer will not draw detergent up
I posted an answer to no soap on the Karcher Factory-Reconditioned 2,600 PSI 2.3 GPM Gas Pressure Washer G 2600 VHR. Same machine I suppose, but use the black 65 l degree low pressure nozzle.
It's in the manual , I missed it and had a hell of a time trying to figure it out. If that doesn't work check the check valve on the pump(Where the soap hose is) , see if it's gummed up.
Be careful taking it off there's a spring and ball bearing in there.
Apr 09, 2013 | Karcher Garden
I have a Karcher K3.540 pressure washer. Won't take up detergent and motor pulses ever second if vari-lance increased towards maximim. Motor runs ok at lower pressure but can take 1min to start wh
This fault is within the control head, under the detergent valve is a small spring loaded valve that acts to induce the detergent, this will have failed, the shaft of the component breaks off the disk base leaving a small hole in the centre of the disk. This is enough to allow pressure past the component. The machine will pulse when operated and will not induce the detergent. I've looked everywhere to find this part as I have a karcher with the same fault.
Jan 22, 2012 | Karcher Garden
Getting error signal about 5 minutes into the cycle
These alarms can mean allot of different things. If you use regular clothes detergant instead of the HE detergant you will get excessive sudsing and that will set a fault. If you overload the washer with bulky items that will set a fault if it is very uneven. If your sediment screen in your water supply hose(s) is getting clogged it will set a fault. If your drain filter underneath the tub inside the cabinet is clogged you will get a fault. Check these items first and repost back here if none of these were the issue and i'll be able to trouble shoot better.
Nov 25, 2010 | LG WM-2277HW Front Load Washer
Jul 20, 2010 | Karcher G 2000 MK 2000 PSI 20 GPM 87cc Gas...
I have a LG WD-8015c washing machine. When I put ...
the best idea is to go to the manufactures website and download the user manual and check in the trouble shooting section for possible remedies eric
Jan 01, 2018 | Washing Machines
Ryobi 3000 psi pressure washer detergent injector
dont have that one but different nozzles for soap spray and valve for soap?
Apr 08, 2009 | Plumbing
Oct 18, 2007 | Karcher 2500 PSI Pressure Washer
Garden Logo
6,573 people viewed this question
Top Karcher Garden Experts
John Trevino
JOHN LAPIER
Joseph Mueller
Joseph Mueller
Are you a Karcher Garden Expert? Answer questions, earn points and help others
