Unit was working fine until had a cold day an turn the heater on. Now blower will not shut off unless we turn the breaker off.
Only 2 thinks can keep ur blower running, one is a bad t-stat, 2nd is ur fan relay on control board, in your blower compartment u have ur t-stat wires going in, turn breaker off remove the g wire from board, usually green, g energizes ur fan relay, turn breaker back on if fan still runs that means ur fan relay is stuck in the closed position, if fan stops replace thermostat
Blower relay stuck in.
SOURCE: Inside blower not starting every time
This should have a time delay sequencer for the blower in the a/c mode. These are bad about being interminent in the a/c mode and also in fan. I have had some that would freeze up and I would get there and the fan be running. Thaw out and check and everything be ok. Got to cycling the fan on and off and sooner or later it would get where fan didn't come on. After replacement the customer didn't have anymore problem. Check the rely, looks like a heat sequencer but mounted on plate to blower compartment.
SOURCE: Fan won't come on, either when heater or air-conditioner is turned on.
you have lost all control voltage. that is generated in the furnace. either the transformer has failed or the fuse in the transformer board has blown or the circuit breaker to the furnace has tripped or you have an open circuit to the furnace in the high voltage wiring. grab a volt meter and start with checking high volts at the furnace and back to the panel. if you have volts then start checking to see if transformer is generating low volts. as a side, if this is a furnace be sure the door is on secure and the door safty switch is depressed or guess what! no fan no volts no nothing. if any lights on board are flashing etc then you have power and it becomes a control problem. be sure your low voltage is getting sent to the stat via red and common on the furnace terminal board. good luck
SOURCE: In AUTO; blower won't come on when i turn heater/AC on.
most likely the heating speed relay on your furnaces IFC board has failed.Unfortunately the entire IFC must be replaced to repair this. you are in need of a professional service tech. The same control handles the blower fan, ignition system and safeties. Not a do-it-yourself repair as wires in the wrong place could cost you a house.
SOURCE: blower never stops. AC outside jammed to stay on???
You need to call someone who truely knows what they're doing. From your decription, the person you had out should not be working on units. You have a problem most likely caused be the person that installed the new motor and these units are not designed to be worked on by the homeowner. There are hazards that could cause damage or injury.
