When I try to enter aq signature it tells me I exceed my limit and this is on the first letter how do I change the settings
You go to settings in the messageing part of the menu..
thenn..go to the last one that says "signature" then click custom then type yours in
How do u change ur signature? i finally figured out how to put one on but now i want to change it! How? plz some one help me i have the envy 2
How to get a signature
If you are talking about your signature that goes into a text message, then you need to make sure you aren't trying to center it, because you can't do that, and it takes up space. Other than that I dont know what signature you are talking about. Sorry. Good Luck.
Note To add your signature when replying to or forwarding a message, the signature options on the Message tab become available after you click Reply, Reply to All, or Forward.
Note These options are not available if you use plain text as your message format.
Note If you want your
changes to appear in the signature in a message that you currently have
open, you need to update the existing signature. On the Message tab, in the Include group, click Signatures, and then click the signature.
Tip You can make changes to signature in a
message that you currently have open by editing the signature in the
message body. However, these changes will not be saved for other
messages.
Change the signature included in an individual message
i was able to put a signature under my text messages but when i turned it off and back on it was the same signature it wont let me change it. now it says its on but no signature and no option to change it.
When I try to put a signature on my enV it says no text to insert. Am I trying it wrong? How do U put a signature on it?
