Right click on the D:/Poppack-setup.exe -> Properties = Compatability Tab.
There should be a box that says "Compatibility Mode" that you need to chek, and then select Win95 and hit OK.
Try installing again.
If it still gives the same error, go back to the tab and go lower than the Compatibility Mode box, to Display settings, and chek "Run in 256 colors" and "Disable Visual Themes"
Try again.
If it still wont work, please respond. If it gives a different error at any time or a different problem, please respond.
You may check for a patch for Windows Vista in the Software maker's website ar may revert to compatible version of Windows, if gaming is more important than interface.
http://www.scanner-drivers.com/drivers/59/59878.htm the link above will take you to the drivers you require, it says windows me but also in the comments it says for XP as well. I hope this works for you.
Is there a error message or something?
What the installer wizard says?
